Can anyone advice how to fix Co channel interference
Any articles to read is appreciated.
Dear Customer.
There are some ways to lower the co-channel interference.
1. Channel planning: We suggest turning on the DCS feature, and setting the DCS schedule at midnight and disabling client aware to avoid serve impact. To know more about DCS configuration, please take a look at this FAQ https://community.zyxel.com/en/discussion/14121
2. Fine tune AP power: We could select the Deployment selection based on your AP deployment, or custom to set the customize power value by going to Access point >> Configure >> Radio settings >> Deployment selection & Maximum output power
3. Adjust channel width: Choose 40MHz or 20MHz instead of 80MHz to lower the co-channel interference. To configure this issue, please go to Access point >> Configure >> Radio settings >> Channel width
4. AP deployment: Well deployment can greatly improve the effective wireless transmission and reduce the error and re-transfer mission packets, we suggest using the ceiling mount and avoid shielding between AP and client.
Zyxel_Judy said:
Dear Customer.
To lower the co-channel interference, normally, you can adjust from 80MHz to 40MHz. If the situation is not better, then down to 20MHz.
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
