Where is gone the twonky media server ?
sitro
hello,
on my nas 542, the twonky server has disappeared.
I think but I'm not sure if it's due to the firmware update.
Can you confirm me the deletion of Twonky or is it a bug?
some information to complete my question:firmware : V5.21(ABAG.9)I did a little tour in the file system and I don't see any twonky package :
<div>root@NAS542:/# ls -al i-data/e0c90389/.PKG/</div><div class=" Quote">total 68</div><div class=" Quote">drwxr-xr-x 17 root root 4096 Apr 27 2021 .</div><div class=" Quote">drwxrwxrwx 19 root root 4096 May 12 2020 ..</div><div class=" Quote">drwxr-xr-x 8 root root 4096 Apr 23 2019 Darkstat</div><div class=" Quote">drwxr-xr-x 7 root root 4096 Jun 5 2018 GoogleDriveClient</div><div class=" Quote">drwxr-xr-x 7 root root 4096 Apr 23 2019 MetaRepository</div><div class=" Quote">drwxr-xr-x 7 root root 4096 Sep 28 2018 NFS</div><div class=" Quote">drwxr-xr-x 9 root root 4096 May 9 2018 PHP-MySQL-phpMyAdmin</div><div class=" Quote">drwxr-xr-x 10 root root 4096 May 16 2018 RandomTools</div><div class=" Quote">drwxr-xr-x 8 root root 4096 May 14 2020 SqueezeCenter</div><div class=" Quote">drwxr-xr-x 8 root root 4096 May 17 2018 SqueezeCenter-7.9.1</div><div class=" Quote">drwxr-xr-x 8 root root 4096 May 15 2018 Transmission</div><div class=" Quote">drwxr-xr-x 7 root root 4096 Apr 27 2021 WordPress</div><div class=" Quote">drwxr-xr-x 7 root root 4096 May 16 2018 ffp</div><div class=" Quote">drwxr-xr-x 8 root root 4096 Aug 14 2020 gallery</div><div class=" Quote">drwxr-xr-x 10 root root 4096 Jan 6 2021 myZyXELcloud-Agent</div><div class=" Quote">drwxr-xr-x 10 root root 4096 May 18 2018 myZyXELcloud-Agent.sav-parjnc</div><div class=" Quote">drwxr-xr-x 10 root root 4096 Sep 29 2019 sav.myZyXELcloud-Agent</div><div class=" Quote">root@NAS542:/# </div>
# ls -al i-data/e0c90389/.PKG/ <br>total 68<br>drwxr-xr-x 17 root root 4096 Apr 27 2021 .<br>drwxrwxrwx 19 root root 4096 May 12 2020 ..<br>drwxr-xr-x 8 root root 4096 Apr 23 2019 Darkstat<br>drwxr-xr-x 7 root root 4096 Jun 5 2018 GoogleDriveClient<br>drwxr-xr-x 7 root root 4096 Apr 23 2019 MetaRepository<br>drwxr-xr-x 7 root root 4096 Sep 28 2018 NFS<br>drwxr-xr-x 9 root root 4096 May 9 2018 PHP-MySQL-phpMyAdmin<br>drwxr-xr-x 10 root root 4096 May 16 2018 RandomTools<br>drwxr-xr-x 8 root root 4096 May 14 2020 SqueezeCenter<br>drwxr-xr-x 8 root root 4096 May 17 2018 SqueezeCenter-7.9.1<br>drwxr-xr-x 8 root root 4096 May 15 2018 Transmission<br>drwxr-xr-x 7 root root 4096 Apr 27 2021 WordPress<br>drwxr-xr-x 7 root root 4096 May 16 2018 ffp<br>drwxr-xr-x 8 root root 4096 Aug 14 2020 gallery<br>drwxr-xr-x 10 root root 4096 Jan 6 2021 myZyXELcloud-Agent<br>drwxr-xr-x 10 root root 4096 May 18 2018 myZyXELcloud-Agent.sav-parjnc<br>drwxr-xr-x 10 root root 4096 Sep 29 2019 sav.myZyXELcloud-Agent<br><br>
I have the configuration directory of twonky :# ls -al i-data/.media/twonkymedia/<br>total 2824<br>drwxrwxrwx 6 root root 4096 Nov 4 17:20 .<br>drwxrwxrwx 6 root root 4096 May 9 2018 ..<br>drwxrwxrwx 6 root root 40960 Nov 4 17:45 db<br>-rw-r--r-- 1 root root 80 Nov 4 17:20 db.info<br>-rw-r--r-- 1 root root 80 Nov 4 17:16 db.info_bak<br>drwxr-xr-x 2 root root 4096 May 9 2018 ddb_updates<br>-rw-r--r-- 1 root root 2756608 May 12 2021 media-statistics.dat<br>drwxr-xr-x 6 root root 4096 Jul 19 16:44 pdb<br>-rw-r--r-- 1 root root 351 May 12 2021 report-info.xml<br>drwxrwxrwx 2 root root 4096 May 9 2018 shared<br>-rw-rw-rw- 1 root root 6 May 13 2021 tsversion<br>-rw-r--r-- 1 root root 0 Nov 4 17:17 twbyebye<br>-rw-r--r-- 1 root root 299 May 9 2018 twonky-config.html<br>-rw-r--r-- 1 root root 306 Nov 5 2019 twonky-config1.html<br>-rw-r--r-- 1 root root 717 Nov 4 17:19 twonky-locations-70.db<br>-rw-r--r-- 1 root root 177 May 9 2018 twonky.dat<br>-rw-r--r-- 1 root root 32468 Nov 4 17:17 twonkyserver.ini<br>root@NAS542:/# <br><br>
I cannot access the web page http://NAS542:9001/ From the panel :
I look a little bit more on the website of Zyxel.The question was already asked there without answer : https://community.zyxel.com/en/discussion/6338/nas-542-twonky-server-not-reachable-via-9001-port https://community.zyxel.com/en/discussion/6338/nas-542-twonky-server-not-reachable-via-9001-porthttps://support.zyxel.eu/hc/fr/articles/360003647159-NAS-Series-Configuration-du-serveur-Twonky-Media is talking about the 9001 port.Anyway, there is not access, the port is not open.
That other thread is from 2020, so it's not the last firmware update which killed Twonky. I never used Twonky myself, but AFAIK it's a build-in function, and so it won't show up in ../.PKG/.Maybe something is wrong with it's cache, preventing it to start. You could try to rename /i-data/.media/twonkymedia and reboot.
the tips doesn't work.After reboot the state is the same.0
Hi @sitro
After check the configuration of the twonky server, the port of the server has been changed to other port.
If you need to change the port back to 9001, you can use winscp to get the file from the NAS and after modified it, and then put the file back.
Before modified it, please always copy a original file before doing any action on it.
I don't know what is winscp. I'm on linux station.No, you are making a mistake.
In the configuration file, the port is 9001 for http and 9443 for https (TLS). There is no change at this level.
Anyway, as you can see in the scan of open ports, neither of them are open.
ok, Answered on the other thread
Twonky is gone – out of business and “deprecated” even though it worked well and I miss it dearly on my EX2 and EX4100 NASes. I’m looking for something and I’ve gotten Plex – it works, but I don’t like it. Twonky was good for me because it allowed me to use the Windows directory structure to find stored movie files.
What do you mean the twonky is gone? If you had enable the service on NAS, you'll see it on the web GUI0
- 588 USG FLEX H Series
- 476 News and Release
