Unregister nwa1123-ac pro
Hi i did get 2 nwa1123-ac pro and a wac5302D-S all of them gives the error that the devices are already registered. I cannot remove them because i don't have the information of the old company to get it removed. Who do i need to contact to get them unregistered?
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 346  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    edited January 2023
    Dear @MK50
    Please download our Nebula APP on your mobile phone to scan the QR-code located at the back of the AP or on the brown box, so the device will register to your organization.
    This mechanism, is to force register via QR-code to his/her organization because we assume only the current owner will be able to scan the QR-code as the device is already on your hand.
    You may get a pop-out message when registering, please click "Register device" on the right-hand side and click "Next" on the top-right.
    I hope this information helps.
    Ivan
  • Mk50
    Mk50 Posts: 2
    Hi Ivan firstly thanks for your reply. I don't have the boxes only the serial number and mac adresses. When i try it gives the error: already registered.
  • Zyxel_Ivan
    Dear @MK50
    If you have no QR Code and you’d like to link to the Nebula with the devices, you can follow the instruction below:
    Or you’d like to keep the device on premises, please PM me the information below :
    1. Invoice
    2. The picture of the devices
    3. MAC address of the devices
    4. Serial Number of the devices
    Thanks.
    Ivan
  • Zyxel_Ivan
    Dear @MK50
    1. Invoice
    Thanks.
    Ivan
    Dear @MK50
    Thanks for providing the information.
    I have transferred the device owner to your account, please check and let us know!
    Ivan Liu
Service & License Help Center
