NR7101: PCI SCAN not working
ngervasi
I'm trying to scan PCI to be able to select some cells based on the signal quality in "Cellular Lock(LTE)" screen but the scan doesn't return any result. The unit is connecting fine but it doesn't list the available cells; broadband is set to 4G/PS Only with Band Autoselection turned on.
I'm on firmware 1.00(ABUV.4)C0 / RG502QEAAAR11A03M4G.
Any suggestions?
Any suggestions?
Same problem. It returns no results. Really important feature , hope it can be solved asap. Firmware version is V1.00(ABUV.4)C00
No change with Firmware V1.00(ABUV.5)C0 😭😭😭😭😭0
I have same issue on V.6 - does anyone know why this happens - I am UK Based.0
Latest firmware is ABUV7 and latest module is R11A07. Upgrade and it will work.1
It's still not working for me even with ABUV7 and R11A07. Any hints?0
So no reaction when you click on the yellow Scan?
Nope. Nothing happens on screen but at elast now I don't have errors in the browser console.0
Hmmmm.........
No, it's the same UI, it's just the scrollbar that hides the first options:
Current Firmware Version: 1.00(ABUV.7)C0
Current LTE Module Version: RG502QEAAAR11A07M4G
- 430 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 354 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 82 Security Highlight
