NR7101: PCI SCAN not working
Goodmorning, same for me but for 5G Cellular Lock.I'm sure that I have N78 band available from Vodafone IT.Right now the router is inside home, not outside, just for testing. Maybe I can't see 5G radio because of this?Current Firmware Version: 1.00(ABUV.7)C0
Current LTE Module Version: RG502QEAAAR11A07M4G
You can't use Cellular Lock if you use 5G NSA only 5G SA.1
SELBERG said:You can't use Cellular Lock if you use 5G NSA only 5G SA.Thank you so much!At this point I have another question: how can I force NR7101 to use 5G NSA or how I can see if it can reach 5G NSA bands?Sorry but It's the first time I configure a 5G router (coming from tp-link MR-600).Thank you again for all the advices you can give me!0
Network setting/broadband/cellular band, use droplist.0
Hello @Mayone78
If you set the Preferred Access Technology to Auto and Band Auto Selection to Auto as well, according to item F in the following article for NR7101 https://support.zyxel.eu/hc/en-us/articles/4404106191890-NR-5G-Series-Basic-Troubleshooting#h_01G2PQ53X2SW7YZ9HX685JVWS1 , then you should be able to use 5G NR-NSA as well as 5G NR-SA when available.
I hope that this is helpful.
Kind regards,
Tony0 -
it’s almost two years and several new firmware versions since this was reported and it hasn’t been fixed yet. Can some please let us know how to be able to scan using this device and it’s web UI?
What firmware do you use?
1.00(ABUV.8)C0 & RG502QEAAAR13A02M4G
It looks like official support is nonexistent in this community forum. Too bad for us customers who have given a reputable amount of money for your products.
Definitely does work - I've used it a few times here in the UK to fix the 4G LTE connection on my NR7101. Those people with issues, have you tried a factory reset? I've had issues in past with bits of the GUI/Router not working as intended, post FW updates. Factory reset would then iron out the glitches.
- 397 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 52 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 221 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 72 About Community
- 63 Security Highlight
