NR7101 - New Installation - Sim Waiting Available
Minesman
Minesman Posts: 7
edited January 2024 in Mobile Broadband
Hi all,
I am a new user. I have recently installed the NR7101. I have upgraded the firmware but I having issues with the sim card. The system tells me the status of sim is SIM WAITING AVAILABLE. I have tested the sim card and it is working fine. I think it may be related to the DFOTA package but I am unsure. I would welcome any advice. Thanking you in advance.
«1
  • Apologies I meant Waiting Sim Available not Sim Waiting Available
  • SELBERG
    SELBERG Posts: 373  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    edited February 2023
    Maybe you have to type APN manually?
  • Minesman
    Minesman Posts: 7
    Thanks Selberg. I have manually inputted the APN details. I am still getting the same message of Waiting Sim available. I have swapped sim slots but this has not worked either.
    I have also tried to upgrade DFOTA as per this link
    https://support.zyxel.eu/hc/en-us/articles/360021563900-NR7101-Connectivity-issues-and-firmware-fix-for-unsupported-frequency-bands-5G-NSA-B8-N1-
    The system informed the file image of the zip file is not accepted. I have removed the sim card while trying to undertake this upgrade but the same issue still arises.
    If you can provide any assistance it would be gratefully accept.
  • SELBERG
    What firmware are you using?
    Module firmware?
  • Minesman
    Minesman Posts: 7
    The firmware I am using is 100ABUV7C0. I have tried the following Modem Upgrade SOP;
    • RG502QEAAAR01A04-R11A03 (I tried this one first)
    • RG502QEAAAR11A03-R11A06 (I tried this one second)
    • RG502QEAAAR11A06M4G-R11A07 (I tried this one last)
    I used the zip files for all three but the system would not accept any of them as the correct type of image file.
    I then removed the sim card and tried all three zip files again. This also did not work.
  • SELBERG
    What is your module firmware?
  • Minesman
    Minesman Posts: 7
    It is not clear what the version of the module firmware is being used. It does not appear on the screen (See screenshot)
  • SELBERG
    edited March 2023
  • Minesman
    Minesman Posts: 7
    Hi there,
    I tried the file and I got the following error.
  • Minesman
    Minesman Posts: 7
    Hi there,
    I am getting the same error with file.
