Connection troubles with NR7101 after every 24 - 48 hours
Have you tried turning on "Network Monitoring" within Network Setting > Broadband?Network Monitoring periodically checks connectivity and provides connection recovery.Thanks.0
Same here with LTE5398-M904 and V1.00(ABQV.3)C0.
Full reboot is necessary for the connection to come up. After the CellWAN changes the IP (after 24 hours) it stay in the "kern.debug udhcpc: Sending discover..." loop forever.0 -
Try another ISP.
This. My problems were solved by changing to strongest signal (another ISP).
2 -
Hi Selberg
What Switch are you using to POE your NR7101?
You giving it power and recieving 5G? Have been looking for a solution for this for a long time.
Thanks0 -
I use unmanaged PoE+ switch, not a Zyxel and yes, receiving 5G.
NR7101 need less than 30W and also my outdoor wifi unit so it is enough for me.
When connecting a PoE+ unit 2 leds light up/port and only one led if the unit don´t need power….
PoE+ (802.3at):This standard provides up to 30 watts of power per port.
PoE++ (802.3bt):This is the latest and most powerful PoE standard and provides up to 100 watts of power per port.
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
