Firmware V5.36(ABWD.0) issues
Hi, same issue here, ATP500 with v5.36.
@Zyxel_Cooldia is it possible to have a test firmware to resolve this issue?
Or do we have to downgrade to a CVE affected version (like 5.32 / 5.35)?Since the upgrade, I need to reboot the firewall every 4 hours.
Has already been turned out which special configuration is responsible for the issue? Our USG Flex 700, configured with 15 SSL VPN Users, is still running fine without problems or permanent reboots, but we are concerned nevertheless.
Hi USG_User,
It may mostly depends on how many simultaneous users are connecting to the firewall via SSL VPNs and 2FA usage. I've also have a Flex 700 with 23 ssl vpn users configured and very few of them (no more than 3) connecting simultaneously that works fine with 5.36. The affected Flex 700s are having heavy ssl VPNs usage
Regards
Thanks a lot Agor. Indeed, normally not more than 3 streetworkers are connecting simultaneously to our Flex700.
You're welcome
Hi @Zyxel_Cooldia ,
I have the same problems with an USGflex 100 (ABUH). The weekle Update vom 2023-04-28 doesn't fix the problem. Where can in I download the version ITS-23WK17-0504-230401495D / 2023-05-04 10:35:09 for USGflex 100?
Thanks a lot…
We've been having the same issue on 2 VPN100 devices since the upgrade. The devices seem to work reasonably well for people on the lan but all of our l2tp vpn connections and p2p connections stop functioning after about 24 hours. Rebooting the devices resolves the issue.
We're considering downgrading all of our devices today.
Thank you.
I got the new Firmware from @Zyxel_Cooldia
Installed it yesterday morning and so far no issues at all.0 -
@Zyxel: Is it planned to release a new official update soon? Or should all affected customers ask for the ITS lab version now?
The V5.36 patch 1 is going to release, the schedule as below,
FLEX/ATP series : 05/10 (Nebula)
USG FLEX series : 05/11 (on premise)
ATP/VPN series : 05/12 (on premise)
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 684 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
