Nas 326 no me deja acceder
Hola, tengo 1 nass 326 y desde hace 2 días no me deja acceder por web, si escaneo la red veo su ip pero sólo me aparece conexión ftp (pure-ftpd), por web me dice que no responde la ip. he reseteado varias veces y no se resuelve, necesito sacar la información del disco, ¿alguna idea?. muchas gracias.
Hello, I have 1 nass 326 and for 2 days it won't let me access the web, if I scan the network I see its ip but only ftp connection (pure-ftpd) appears, through the web it tells me that the ip is not responding. I have reset several times and it is not resolved, I need to get the information from the disk, any ideas? thank you so much.
Try reboot your nas, check the exact IP address it get from the router and reconnect.
La ip del nass me aparece en la red pero sin acceso web.
The nass ip appears on the network but without web access
That is a portscanner? Is really only port 21 open?
Ya he conseguido acceder, al quitar los 2 discos se ha desbloqueado, como lo he reset y no recuerdo los usuarios que tenia ni las carpetas que habían, ¿como puedo recuperar esos datos ahora?
I have already managed to access it, when removing the 2 disks it has been unlocked, as I have reset it and I do not remember the users it had or the folders it had, how can I recover that data now?
Go to the Shares menu (Control Panel->Privilege and Sharing->Shared Folders) and re-enable the shares.
- 588 USG FLEX H Series
- 476 News and Release
