NR7101: Access Management Service (UI) in IP passthrough (bridge) mode
  • k1s
    k1s Posts: 73 image  Ally Member
    edited July 2023
    @PeterUK In my case and @monty03 we have NR7101 in IP passthrough mode.
    When I connect directly to NR7101 (via it's LAN port on t's PoE adapter) it can be reached using whatever IP address is set under 'default' (e.g. 192.168.x.x).
    That is not what is showing as the IP Cellular Info configuration page. There it shows its IP address as10.x.x.x (which I think indicates my ISP is using CGNAT, referenced earlier).
    However, as soon as the NR7101 is connected to the LAN's router (Synology in my case), the NR7101 cannot be reached and does not respond to a ping, whether it is set with a 192.168.1.x IP or on another subnet e.g. 192.168.3.x).
    PeterUK Posts: 4,446 image  Guru Member
    edited July 2023
    @k1s
    Yes because you connect the NR7101 to your LAN and not to a another WAN
    If you was to disable the router DHCP with the NR7101 connected like that with PC gets a IP by DHCP (renew) you would access the NR7101
  • k1s
    DHCP on the NR7101 is indeed disabled. The PC has a static IP on 192.168.1.x (same subnet as the primary router). I don't know what you mean by "because you connect the NR7101 to your LAN and not to a another WAN" . In pass through mode, the NR7101 is connected to a WAN (Vodafone's in my case) and is supposed to 'supply it - i.e. internet - the the LAN is it not?
    edited July 2023
    As for @monty03
    With your Ubiquiti EdgeRouter you give the NR7101 its own port as WAN.
    You might need help from the Ubiquiti community but you need to route from your LAN interface to SNAT NR7101 interface destination 192.168.2.1
    edited July 2023
    no I mean on your Synology router then make the PC DHCP to get a IP by NR7101 if its in IP passthrough
    as in your router does not have another WAN port as in your current WAN is to another ISP?
  • k1s
    The Synology router has 2 WAN ports, one is connected to a modem which serves internet to the LAN. The NR7101 is connected to the other as a backaup/failover.
    I can't disable DHCP on the Synology router. It needs to serve up IP addresses to half the devices on the LANs
  • monty03
    monty03 Posts: 5 image  Freshman Member
    I set a static route to 192.168.2.1 and can ping the NR7101, but I cannot access the UI (neither on port 80 nor on port 443).
  • k1s
    @monty03 With 192.168.2.1 as the network destination in your static route, what did you set as the netmask (255.255.255.255?) and gateway?
    Right @k1s so if you unplug the WAN with the modem then you can connect to NR7101 Management the reason you can't access Management when your modem is connected is thats all traffic routes down it which means you can't access Management of NR7101 unless your able to make a routing rule.
    @monty03
    No static route is not what you want delete it you need a routing rule
