Problems with connecting multy u
I downloaded The app connected multy u with Ethernet cable to wall rj42 and plugged in Power IT turns blue and when i try to create name and password IT says applying tour wifi settings to multy For like 3 mins and Then says "setting failed multy requires reset. And after i do reset IT just says connection Timed Out when i try to connect.
Hi @Jeppeze
Please initiate a reset of the Multy U device by pressing and holding the reset button using a pin for a duration of 10 seconds. Once completed, release the button. Once the Multy U device has finished resetting and the LED indicator turns blue, proceed with its reinstallation.After Multy U device is reset and the turn LED blue, please reinstall it again.
You can refer to the following steps to set up the Multy U device0 -
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 320 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 399 News and Release
- 86 Security Advisories
- 3.8K FAQ
- 78 Security Highlight
