Zyxel NR5101 5G Router
TemporisCaptial
TemporisCaptial Posts: 2 image  Freshman Member
edited January 2024 in Mobile Broadband
My device has stopped detecting the SIM, please advise a way to resolve this.
Its not the sim, it works in my phone.
Firmware upgrade has done nothing.
Device reset has not changed the status.
Anything else I can try?
  • Friday
    Friday Posts: 114 image  Ally Member
    Hi @TemporisCaptial ,
    We suspect issue may relate to the thickness of nano SIM card and nano adapter,
    is it possible that you add duct tape in the back of the SIM card and adapter to increase the thickness and see if slove the issue?
    thank you !
  • TemporisCaptial
    Thank you for your response.
    I can certainly try this however I've since worked out that it only seems to not detect the SIM when trying to use 5G, when I change to 4G the router works (same SIM).
  • Friday
    Thank you for providing the crucial info.
    Is your sim a 5G sim card? can you check the supported 5G band and
    select that specific band on GUI?
    by accessing Broadband>Cellular Band>Band Management
    disable Band auto selection.
    Thank you !
  • dzmitry_lahoda
    dzmitry_lahoda Posts: 2
    edited June 2024
    i have similar issue. sim disappeared in zyxel after months of work(so with some one or two a day offline periodical for some minutes).
    now visible and working in phone.
    cleaned up sim, was covered by some thing (after months just being in zyxel, place is not wet as other devices and wood are ok here).
    sim was made visible, but pin input apply failed several times.
    moved sim out, removed pin in phone, inserted back, does not see sim.
    tried other sim, restarts, etc. sim is not visible.
  • tried to upgrade firmware, did not help
