Unable to delete some files
Zetec
Zetec Posts: 11 image  Freshman Member
In a Nas 326 I have a folder with some files that I cannot delete in any way. They are files created years ago by a now defunct PC and every time I try to delete them the message "requires authorization from [nas name]/admin" appears. I try both from Windows and from the file browser inside the NAS, but I can't delete them, I can only modify them. Do you have any ideas? Thank you.
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    Login as root, using your admin password.
  • suisei
    suisei Posts: 120 image  Ally Member
    First Comment First Answer Friend Collector Second Anniversary
    You can SSH access into the NAS326 with you admin and password and use the linux type command to remove your folder.
  • Mijzelf
    type?
  • Zetec
    Sorry but I can log into linux as superuser but I don't know where the folder is. If it were Windows ok, but I've never used Linux. Thanks.
  • Mijzelf
    Using WinSCP you'll have a graphical interface. The shares are located in /i-data/<some-hex-code>/ when it's an internal disk, and in /e-data/<some-even-longer-hexcode>/ when it's an external disk.
  • Zetec
    I found the files to delete but when I delete them I get "error 3 permission denied". If it helps, these files were in a dropbox folder.
  • Mijzelf
  • Zetec
    It worked! A thousand thanks!
  • suisei
    Sorry, I mean the Linux base command line. rm….
    Yes, use Winscp, it would be more easier to do it.
