NSA 325 v2 and NFS
Yes, that's the one I have tried. For some reason I even cannot ping zyxel.diskstation.eu or do I misunderstand something here? Also did change the DNS as described above but without any success.FireBall said:Just checked the link and it’s working for me. Did you use this one?:
http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/zyxel_fw4_zypkgs/0 -
Hi, trying to access both links you shared but none of it works for me.
Got 325 v2 for free and trying to make it a local backup place for Synology.
My first contact with Zyxel so any help/step-by-step guide is much appreciated.
Meanwhile there is a third, https://metarepo.tk/Users/Mijzelf/zypkg-repo/fw4_stock_packages/
Thanks, this one I can see.
How do I install a Backup Planner now on a 325v2?
Hello I agree with the question. How can you install the packages on the NSA 325 V2? I have new hard drives in it and the package center is offline :-( Unfortunately, the instructions/pages for Metarepo are all offline. Best regards
there are two ways, first one is using MetaRepo (explained in previous posts).
The second way, I found easier to use and it did work on my NSA325v2.
1. Enable \admin SMB share (It is preconfigured, but disabled by default).2. Drop the entire content from "fw4_stock_packages" to "\\*nas_name*\admin\zy-pkgs\" folder.
3. Reload the Packages page in the web UI; All packages will show up and you can just install them.
Many thanks for the answer.
explained in previous posts - Yes, unfortunately the links are offline
Enable \admin SMB share (It is preconfigured, but disabled by default). - If you could please tell me where I can set this up?
To Enable the /admin share, navigate to: Sharing -> Shares; select "admin" in column "Share Name". Click "Edit Share", make sure "Enabe This Share" is ticked and hit apply.
Now the /admin share should be visible when you navigate to \\*nas_name*\ using Windows Explorer and the NAS admin credentials.
Excellent. That's exactly it. Thank you
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
