LTE7480-M804 loses connection and stays disconnected until next reboot
Thank you for the tip! Didn't know there were new versions after ABRA.4.
I will try ABRA.6 as soon as I can and report back.
I am now running ABRA.7 since 2 months ago.
I now have a script that restarts the modem if pings fail, and logs the event. No restart was ever triggered so far, so maybe the issue was resolved in these versions?
Not sure why it wasn't mentioned anywhere in the changelog though.
I will update if the issue reappears.
May you share the script please?
I'm experiencing the same problem with LTE5398-M9040 -
I am actually using a smart switch on the modem to turn it off and back on if pinging google.com doesn't work.
The script is running on another router in the same LAN network, and the smart switch is connected to this second router's wifi. The cron runs the script every 5 minutes. You can turn the logging off if you don't care about that.
This is far from an ideal solution but it works so I didn't want to spend any more time on it. I'm open to improvements though!
#!/bin/sh # Set the URL to ping url="google.com" # Set the maximum number of retries max_retries=3 # Set the delay between retries (in seconds) retry_delay=20 # Counter for failed pings failed_pings=0 # Counter for ping retries current_try=1 # Function to log the restart log_restart() { echo "$(date '+%Y-%m-%d %H:%M:%S') restarting" >> restart_modem.log } # Ping the URL and check the exit code while true; do # Print the current try echo "Try $current_try of $max_retries" current_try=$((current_try+1)) if ping -c 4 "$url" >/dev/null 2>&1; then # All pings were successful, so quit the script echo "online :)" exit 0 else # At least one ping failed failed_pings=$((failed_pings+1)) if [ "$failed_pings" -eq "$max_retries" ]; then # Reached maximum number of retries, so print "offline!" echo "offline!" # Turn smart plug off, wait 5 seconds and turn it on again wget -q --spider ENDPOINT_TO_TURN_OFF_YOUR_SMART_PLUG sleep 5 wget -q --spider ENDPOINT_TO_TURN_ON_YOUR_SMART_PLUG # Log the restart log_restart exit 1 else # Wait for the retry delay before trying again sleep "$retry_delay" fi fi done
so your script don't really restart the router,
it only turns off a smart plug where the router is connected.
have you tried one of those?
udhcpc -q -f -i wwan0 (refresh the dhcp client and reset the lease time)
cfg cellwan_mapn edit --Index 1 (refresh the LTE connection)
sys resetcm (restart only the LTE module)
thanks to @JeanFrancois ;-)0 -
Oh my sorry for the formatting there, the post needed approval (for the code snippet I guess) and the intro text didn't look like that in the preview…
Anyway I'm going with this dirty smart switch solution because I don't have root access to the Zyxel 4G modem. I do have another router running OpenWrt so I'm able to use that script there and manage a Shelly smart switch.
It would be great if I could access the Zyxel to run scripts and manage crontab!
Look at
https://openwrt.org/toh/zyxel/lte5398-m904
to discover r00t passwd0 -
Do you know whether that applies to the LTE7480-M804 too?
Yes (I suppose, because i don't have that router)
btw: in my opinion, if you buy/own a router,
the manufacturer must supply his root password to you.1 -
I totally agree!
Finally had a chance to play with the Zyxel and I got root access! Thanks a lot for the guide, it definitely applies to my model too since it's the same software.I didn't setup a script yet but I'll look into those suggested by you above.
Thank you very much 🙏
- 431 Beta Program
- 2.6K Nebula
- 169 Nebula Ideas
- 6K Security
- 375 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 265 Service & License
- 409 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
