NAS542 - Teardown video/instructions?
JockeSve
JockeSve Posts: 82  Ally Member
Does anyone have instruction (or video) of how to open NAS542 entirely?
(Didn't find anything on Youtube or via Google search… 😐️)
I just realized how much dust it has collected inside the chassis and thought that a proper cleaning might keep the temp down a bit at least…
  • Mijzelf
    Mijzelf Posts: 2,763  Guru Member
    In the past have opened both a 326 and a 540. In both cases it's basically removing every visible screw, and splitting the housing on two seams. As far as I remember the seams on the 540 were harder than the seams on the 326. The latter could be opened with some careful prying. On the 540 I needed a table knife to pry open the clips on the inside, while the steel frame was still inside.
  • suisei
    suisei Posts: 110  Ally Member
    First Comment First Answer Friend Collector First Anniversary
    I've found some helpful videos that might assist you. However, I couldn't find a disassembly guide specifically for the Zyxel 540.
  • JockeSve
    Thanks @suisei!
    Yes, I saw these, however I'd like to see if there are any model specific differences to be aware about when disassembling the unit.
  • Mijzelf
  • JockeSve
    OK, thanks for answers!
    I'm going to give it a try as the box looks like it needs a thorough cleaning… ;-)
