Multy U unstable bridge mode
I have a router + 4 Multy U in a daisy chain configuration. So the primary Multy is connected to the router and the others in a chain to the primary Multy. The router is also wired to some other devices. I would like to have everything on the same subnet and therefore I selected Bridge Mode in the Multy app. This mode activated and everything worked as it should for a little while. Then suddenly the primary Multy was rebooting several times and was back to NAT mode. This behaviour repeated many times and here are also frequent disconnections where I have to manually reboot the primary Multy. When I do it manually (i.e. by turning it on and off again), bridge mode usually - though not always - remains active.
Is this expected behaviour or is there something wrong? I also tried changing the subnet mask to 255.255.0.0 in my router but it didn't help either.
Is there anyone else experiencing this or has a suggestion for a solution?
As I found in the thread of this article. you can try with the set up of this topology and then recheck it. Or you may reset all devices and change their position and also devices and re set up again.
thank you, this is how my network is currently set up (the version without the switch). I also tried up reset everything and even used different units as the primary multy. No imprudence so far. I just have the feeling the product is not really fully developed
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
