zyxel 8-port 2.5g multi-gigabit unmanaged switch
why don't you coupler port 1 cable to port 2 cable
I don't understand this statement. Please explain.
As for a managed switch, your link results in:
Sorry, we can't find any items. The products you are looking for might not be available in your regions.
Search: XMG1915 Series
Oh, and btw, 8 port 2.5 managed switches are about $500. Too rich for my blood.
⇒ Could you please let us know which region you are in? Also, could you clarify which device you are referring to that costs $500?
Nami
I am in the US.
Zyxel,
So I captured the router error I get when the router tries to get a WAN IP through your switch.
I am also showing, error 2, what happens when I try to set the router to a static IP the same as what the ISP assigned to me dynamically. I clicked the Use Static button to see what it was giving me. So that is where the 10. address comes from.
Needless to say it does not work.
I also discovered that the local client cannot get a LAN IP if going through your switch. I had to plug it into the router.
Again, I can get it to work, until I reboot the router.
Hello @Lefty_Insider
To assist you better, could you please send your contact information via private message? Just click on my name and then select "Message". Our local support team will then reach out to you to discuss the most suitable models and purchasing options for your needs.
Could you please provide a screenshot of the Hiltron modem's setting? We assume that the modem has not been set to bridge mode (Modem Only Mode), and enabled the DHCP server.
The reason for our assumption is that your router receives a private DHCP IP (10.0.0.2), which might be assigned from the modem (DHCP Server).
If you want the router to perform NAT and DHCP functions, the modem should be configured to "Modem Only Mode", and acts as a bridge. This configuration allows it to forward the public IP from the ISP directly to the router. Please double check this link that user @PeterUK sent earlier or contact your ISP for help, then please send the capture of modem’s setting page to us.
Thank you
Nami
You or I are a bit confused here. I do not have a Hitron CGNv4 modem/router. I have a ISP supplied Hitron EN251 2.5 Gbps modem. I have no login credentials for it.
The router was performing NAT and DHCP functions prior to me including your switch in the network.
ME: Is the Hitron EN2251-RES 2.5 Gbps modem also a router?
CHATGPT: The Hitron EN2251-RES is a cable modem designed to support high-speed internet connections up to 2.5 Gbps. However, it does not function as a router on its own. Typically, you would connect the Hitron modem to a separate router or gateway device to distribute the internet connection to multiple devices within your home or office network. If you need both modem and router functionalities in a single device, you might want to look for a modem-router combo unit.
So from what we know you have a modem and you only get one WAN you also have the modem to the unmanaged switch then to router but you then connect router LAN to unmanaged switch which is the problem.
So going by Nami layout
you need a coupler
that joins modem to router that are by ports 1 and 2
So the cables now go from modem WAN port to the switch port 1 and from switch port 2 to router WAN port. Where would the coupler go?
I hate to seem dense but I don't get what you are suggesting.
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
