Win 11 and SMB2 for NSA325v2 - Firmware NSA325_4.81(AAAJ.1)
  • django_alexander
    django_alexander Posts: 5
    edited May 2024
    This is updated version for smb.conf [global]; I highlighted what is important for the operation of the shares
    [global]
    workgroup = YourWorkgroupName
    domain master = no
    local master = no
    preferred master = yes
    os level = 100
    server string = NSA325
    netbios name = NSA
    dos charset = UTF8
    display charset = UTF8
    unix charset = UTF8
    security = user
    encrypt passwords = yes
    smb passwd file = /etc/samba/smbpasswd
    guest account = pc-guest
    map to guest = Bad User
    write ok = yes
    force create mode = 777
    force directory mode = 777
    force security mode = 777
    force directory security mode = 777
    auth methods = guest sam_ignoredomain
    max log size = 50
    host msdfs = yes
    lanman auth = no
    client lanman auth = no
    client NTLMv2 auth = yes
    ntlm auth = yes
    kernel oplocks = no
    socket options = IPTOS_LOWDELAY TCP_NODELAY SO_SNDBUF=131072 SO_RCVBUF=131072
    use mmap = yes
    max xmit = 131072
    min receivefile size = 128k
    unix extensions = no
    wide links = Yes
    oplocks = yes
    level2 oplocks = no
    max smbd processes = 128
    printing = cups
    printcap = /etc/printcap
    load printers = yes
    use sendfile = yes
    passdb backend = smbpasswd
    veto files = /.grive*/
    ; End of File
    PS. To access the network from Windows XP PRO without problems, check in Services that you have the "lan man" service disabled or manual and that you have the NT LM service, (Started) Auto or something similar. Win XP pro support only SMB V1; if you don't have old devices with outdated operating systems on your network, you can force samba on the Zyxel NAS to work exclusively with SMB V2, but if you have XP, it doesn't support SMB v2.
  • And if you want to use Network Discovery in Windows 10 you must use this in smb.conf:
    local master = no
    preferred master = no
    os level = 20
    IF NSA Become Master Browser … By by Network Discovery :)
  • And in windows 10 secpol.msc i selected:
    Send NTLMv2 response only. Refuse LM &NTLM
  • Deaconbrown
    Deaconbrown Posts: 6 image  Freshman Member
    First Comment Sixth Anniversary
    Hi All
    I am so alien to what you are talking about and how to install this update on both my NAS325v2 and NAS542.
    Could someone point me in the direction of a dummy step-by-step instructions on how to do what's needed from start to finish?
    I did do some looking into it all and came across an app called Putty, which i managed to use to connect to my NAS542. But after that, I was lost on how to start the update. Was PuTTY the right app to use?
    So sorry to be a pain about this
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    The two URLs in the solution post are now
    https://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/
    https://zyxel.diskstation.eu/forum/viewtopic.php?f=4&t=24
  • Techlobo
    Techlobo Posts: 1 image  Freshman Member
    Neither the zyxel.diskstation.eu nor the metarepo.tk domains appear to be operating currently.
    Is this temporary or are they no longer available?
  • Mijzelf
    Don't know. I pinged the administrator of that website, but he hasn't answered yet.
  • Mijzelf
    edited December 2024
    @Techlobo : That administrator didn't answer, and the websites didn't come back. So maybe he lost his interest, or worse.
    I have an old backup, which I put here: http://mijzelf.duckdns.org/zyxel/zypkg-repo/. It is old, and I don't know what changed in the mean time. But it can't be much.
  • ArghUrgh
    ArghUrgh Posts: 2 image  Freshman Member
    Hey there,
    I finished the zyxel-samba-replacement and everything seems to work fine. I removed the legacy smb 1 feature in Windows 11 and my NSA325v2 is still reachable, but "smbstatus -V" gives me "Version 3.5.6". Can this be true? Shouldn't it be "3.6.25" from now?
  • Mijzelf
    If you use the right version of smbstatus. This is the firmware one. So try /opt/bin/smbstatus
