zyxel 8-port 2.5g multi-gigabit unmanaged switch
    PeterUK Posts: 4,437 image  Guru Member
    have your ISP give you 2Gb speed and you will see your limited to 1Gb
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hi @Lefty_Insider
    All your devices, not just the computer connected to the 1G LAN port of the router, are limited to a 1G connection. When these end devices need to access the internet, their traffic first goes to their default gateway, which is the 1G LAN port of the Netgear router, not to the modem.
    Imagine your home network like a system of roads. All your devices (cars) need to go through a checkpoint (router's 1G LAN port) before they can reach the highway (internet). The checkpoint is only one lane wide (1G speed), so no matter how fast the cars can go or how wide the highway is (2.5G on the WAN port), they must slow down to pass through the checkpoint.
    Regarding the screenshot you shared, it indicates the link speed between your PC's network adapter and the connected device, not the actual speed your PC achieves when the traffic goes to the modem.
    Untitled Image
    Nami
  • Lefty_Insider
    Lefty_Insider Posts: 28 image  Freshman Member
    Seems that you are both right, but would need too setup Performance Test on a machine on the other side of the modem to verify.
  • Lefty_Insider
    Seems like I can't get anything close to 2.5 Gbps through these switches anyway.
  • Zyxel_Nami
    Hi @Lefty_Insider
    Which device is 172.16.0.8?
    Is it the speed test between local devices connected under your unmanaged switches and a local machine that's directly connected to another 1G LAN port of your router?
    Nami
  • Lefty_Insider
    That device is a Win10 Surface tablet with a USB C to 2.5 Ethernet adapter, that I can move around from place to place. Testing was switch to switch, no router involved. Further testing of additional machines revealed the better results attached.
  • Zyxel_Nami
    edited May 2024
    Hi @Lefty_Insider
    The link speed between devices can be influenced by various factors such as network adapter quality, device performance, and CPU load. Please try testing the connection between only two end devices without a switch, i.e., PC A ←→ PC B, to see if they can achieve 2.5G speeds.
    Regarding the router not getting the IP, has this issue been resolved?
    Nami
  • Lefty_Insider
    Direct connection between two PC's is not a real world scenario for me, so I don't care.
    No, the issue has not yet been resolved. I still believe that your switch is the problem. My router can get a WAN IP from the modem, unless your switch, and only your switch, is in between.
    Ok I suggest you get another unmanaged switch but other make I'm sure you will run into the same problem
  • Zyxel_Nami
    edited May 2024
    Hi @Lefty_Insider
    We would like to summarize this forum thread and provide some key points and potential solutions for your network setup.
    Key Points:
    1. Current Setup and Issue:
      • Your current setup includes a Hitron EN251 modem, a Netgear Nighthawk RAXE500 router, and a Zyxel MG-108 switch.
      • Both the WAN and LAN ports of the Netgear router are connected to MG-108, the unmanaged switch, as shown in the diagram. image.png
      • The router can obtain an IP when directly connected to the modem, but not when the switch is in between. After rebooting, the router gets a 10.0.0.2 IP, indicating possible DHCP conflicts.
    2. Understanding the Switch:
      • The MG-108 is an unmanaged switch that doesn't have its own MAC address. It forwards packets based on the MAC addresses it observes from connected devices.
      • This setup can lead to conflicts because the unmanaged switch mixes LAN and WAN traffic.
    Proposed Solutions:
    As mentioned previously in this comment:
    1. Change Topology: Connecting the modem directly to the router, then the router to the switch (modem → router → switch). This setup ensures proper traffic management and avoids mixing LAN and WAN traffic, preventing IP conflicts.
    2. Use a Managed Switch: If you prefer to maintain your current setup (modem → switch → router), upgrading to a managed switch with VLAN capabilities can help segregate WAN and LAN traffic effectively, thus avoiding conflicts.
    I hope this helps clarify the situation and guides you towards a solution.
    Best regards,
    Nami
