Firmware update doesn’t work for zyxel nbg6615
I think one should not rename the unpacked firmware file ….
unsure whether unpacking the firmware file might cause any issues.
When upgrading the firmware, I will ensure to keep the original file naming intact.1 -
Hello @suisei
Thanks for your reply.
When I leave the file naming intact
"C:\Users\User\Downloads\NBG6615_V1.00(ABMV.6)C0\V1.00(ABMV.6)C0.bin"
I end up with an error "This site can't be reached - check the address"..
Kind regards,
Jan
first: dont change the name of the file may be extract unpack it once again, control the file size
second: i dont know your directory structure/access rights Network ? linux ?
→ may be you put it on a usb stick an load it from there ?
— there is no browse dialogue for loading the file , you have to enter the file path and this is the reason that you wanted to simplify the file name ??
may be try this : "\\C:\1\V1.00(ABMV.6)C0.bin"
may be : you have to be in "router mode " not access Point ??
→ Yes, i think its necessary that the device is in Routermode for getting access to the firmware file !
So good luck for you .
Hello @zyxelcz
I don't know if you are still trying this, but the following post might help.
Kind regards,
Tony
- 3K Nebula
- 229 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 665 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 305 Service & License
- 498 News and Release
- 95 Security Advisories
- 5K FAQ
- 89 About Community
- 111 Security Highlight
