Wifi
Bogart
Bogart Posts: 22 image  Freshman Member
I know has been asked before but replies seem very vague so acn someone give me a definitive answer.
LTE74904-M904 4G router can the internet be accessed wirelessly. I can connect to wirelessly to the router but told internet unavailable. Is it possible or not?
«1
  • SELBERG
    SELBERG Posts: 374 image  Master Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    NOT!
    Only for managing your modem.
  • Bogart
    You must be sick of me but can you expalin in a bit more detail.
  • Friday
    Friday Posts: 114 image  Ally Member
    5 Answers First Comment Friend Collector Third Anniversary
    Hi @Bogart ,
    LTE74904-M904 WIFI function is only for management purpose.
    It allows user to login the device for setting, and will disable 30 mins after boot up.
    If you would want to accessed wirelessly with Internet, you will need to connect another router to LTE74904-M904's LAN.
    thank you.
  • Bogart
    Which I have now done. Now one other quick question that you may be able to answer. It says in the LTE74904 user guide, but not the quick start guide, not to mount the device at a height over 2m.
    1 Why is this?
    2 If so why does the quick start guide show it mounted high up at the top of 2 floor house?
    Regards
  • SELBERG
  • Bogart
    Hi
    Screenshots attached.
    Screenshot A is taken from the users manual and as you can see the second line in red type mentions the 2m limit
    Screenshot B taken from quick start guide and shows unit mounted at top of house wall. Either it is avery small house or is along way over 2m.
  • SELBERG
    My antenna is about 4 meters up on the wall.
    I have better signals from there than up on the roof.
  • Bogart
    Hi
    I figured higher the better in theory. Still unsure why 2m is mentioned.
  • Bogart
    Hi
    Right everything was fine until
    I noticed that the Zyxel wifi was on and as I am sure I had disabled it I tried to access the router. For the life of me trying to recall user id and password failed miserably. So I did a reset to try to use admin 1234 did not work So switched on off still no luck and so finally held reset button in for 10 seconds. Ever since then I have no internet, solid green light on router but no access to internet. Any ideas?
    Sorry I am a real pain I know
  • SELBERG
    Cellular APN / Modify / Turn Off IP Passthrough / OK.
    You may need to reboot (not factory reset).
