NAS 542 App installation stops at 45%
Hi @Joerg , @JustAnotherUser and all
We're pleased to inform you that the issue has been fixed. Please refresh the app and reinstall it.
Kay
Thank you for the change and the notification 👍️. I am using the PHPMyAdmin App only as Database for my Raspberrys and a Intel Nuc with Kodi . That runs now without problems . I know there is an Export and Import function in this App . But why change a running system . It takes a lot of time to restore the Database if i make a mistake . Maybe I need another app at some point in the future then I'll take a look at it . Good to know Apps are working now .
Kind regards Joerg
Package index refreshed, smooth and straightforward.
Thanks @Zyxel_Kay for fixing it.
@Joerg enjoy the fix.Regards
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
