WAX630S become offline during 2 minutes multiple times a day
I have 3 WAX630S plugged in a GS1920-48HP. All devices are up to date.
Since 3-4 weeks, the 3 Access Point go offline during 2 minutes multiple times a day (not at the same time). During this time, SSID and internet access remain available. Seems to impact the connection to Nebula only
The logs show :
The switch doesn't have this issue. Can you help me ?
Thank you.
Hi @hexos,
After checking the event logs and diag info, we found this issue is the AP didn't receive server's feedback. This is more likely related to the uplink. We also found that your switch uses a different public IP address to connect Nebula. That's why only the APs have this issue. Therefore, we recommend checking the stability of the AP's uplink, which public IP is xxx.5.
Zyxel Melen0
Hi @hexos,
Could you enable Zyxel support access so we can check it? Please reference this FAQ to enable Zyxel support access.
Zyxel Melen0 -
Hello Melen,
Zyxel support access is now enabled
Hello @GuiseppeR
Not very similar since my APs goes offline "only" 5-6 times a day. From my side it's a netconf issue according to the logs if it can help.
Hi @hexos,
Zyxel Melen0 -
Hello @Zyxel_Melen
Thank you for your feedback. I will try to change the uplink and see what happens.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
