zywall secueextendeur
Hello , I have a Zyxel USG FLEX 50 router (USG20-VPN) , for VPN connections , I use zywall secuextender 4.0.4.0
and depending on where I connect, it works well or not at all, a personal wifi access point, it works, a shared connection, it works from time to time or not at all, a public access point also.
Do you have an explication ?
Hi @baudetd
If you’ve upgraded to SecuExtender SSL VPN version 4.0.5.0 and the issue persists, the problem may not stem from the VPN client itself but rather from the public or shared networks you’re connecting through. The instability or restrictions on public/shared network uplinks could cause such connectivity issues.
Regarding registering your USG FLEX 50 router to your Nebula account, if it’s currently registered to your previous IT partner, you can reclaim the device through its web GUI. Please refer to the following article for step-by-step instructions:
Once the device is reclaimed, you can proceed to register it with Nebula Control Center (NCC). These articles may help guide you through the registration process:
- How to register and unregister USG FLEX series on Nebula Control Center (NCC)? — Zyxel Community
- [Nebula] I cannot use native mode to register and deploy my firewall on Nebula — Zyxel Community
- [Nebula] Why can't I use ZTP to provision a firewall to Nebula? — Zyxel Community
If you encounter further issues or have additional questions, feel free to let us know.
Kay
Hi @baudetd
The latest version of the SecuExtender SSL VPN client is 4.0.5.0, and we recommend upgrading to this version for improved performance and compatibility. Please note that SecuExtender SSL VPN 4.0.5.0 has already reached its End of Life (EOL) status, so we suggest exploring other VPN options for future use.
For more information on the EOL status and alternative VPN solutions, please refer to this article:
In the meantime, please try upgrading to SecuExtender SSL VPN 4.0.5.0 or testing a different VPN option to see if this resolves the connectivity issues you’re experiencing.
Kay
Hello
I have done the update
to version 4.0.5.0 but it doesn't work any better.
to use Use IPSec VPN instead of SSL VPN
i have a free nebula account.so i wanted to attach the usg flex 50 router to the nebula account, and i get an error message saying that the product is already registered. i think it's registered to our old it partner who we no longer work with. how do i unsubscribe the router?
thanks
Hi @baudetd
Kay
- 3K Nebula
- 230 Nebula Ideas
- 6.6K Security
- 667 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 307 Service & License
- 499 News and Release
- 96 Security Advisories
- 5K FAQ
- 89 About Community
- 111 Security Highlight
