Device error, Wrong CLI command, device timeout or device logout.
Hi everyone,
We are regret this issue happens and any inconvenance we caused.
This issue is due to the Application Patrol signature issue.
Please reference this FAQ to resolve this issue:
Since today we are not able to login to our USG FLEX 700 (5.39 ABWD.1) via Web Interface. The USG login window is presented but when trying to login the browser retuns a 504 Gateway Timeout.
Further any SSL VPN Logins via SecuExtender fail as well. Only VPN via IPSec is still available.
Other services are still operable. For example we could reach the internet, and accesses from outside via port forwarding are working as well.
Even in the SecuReporter, nothing is recorded, very strange. 🤔
Received the following message from the FW alert:
No. Date/Time Source Destination Priority Category Note Message
1 2025-01-24 08:49:31alert zysh zysh daemon ZySH daemon is busy.0 -
We have a similar issue since today. Our Atp200 didn´t work in the morning. I turned it off and after a reboot everything is working (Internet, VPN). But I can´t login to the atp "504 Gateway timeout". Whe hafe 2fa activated.
Secureporter says:
Device Disconnected
Device "
ATP200
" is not connected. Please make sure device connection is stable so the log it uploads keeps SecuReporter running.0 -
we similar problem, with 2 atp 200, we have 2fa actived with google auth… it's impossible to reach it after reboot all is down
Correction: VPN is not working.
Same problem with the device atp 200.
There was an error when logging into the web interface: Wrong CLI command, device timeout or device logout.
It doesn't allow access to the web interface right now. And the devices started to fall off. The Internet stops working
When I log in to SecuReporter, I get this message:
There seems to be a major problem with the services at Zyxel. 🙃
same problem on atp 500 and 200
over serial I see the following error:
httpd is dead at Fri Jan 24 08:43:40 2025
App watch dog try to recover httpd at the 3 time
ALERT!!
temporary working folder filesystem usage: 100%
0 /tmp/sdwan_init
0 /tmp/fetchurl
0 /tmp/sdwan_interface
0 /tmp/app_wd_event_trigger
0 /tmp/dual_style
0 /tmp/wtpConfUpdateRecordnot able to login over serial!
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 431 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 428 News and Release
- 89 Security Highlight
