Device error, Wrong CLI command, device timeout or device logout.
Vagabound
Vagabound Posts: 49 image  Freshman Member
First Answer First Comment Friend Collector Third Anniversary
Since this morning I get the above error when I log on to the Zyxel USG Flex 200 via the web interface.
And the web display is empty, nothing can be displayed or operated.
What can I do to resolve this error?
«13456
  • USG_User
    USG_User Posts: 400 image  Master Member
    edited January 2025
    Since today we are not able to login to our USG FLEX 700 (5.39 ABWD.1) via Web Interface. The USG login window is presented but when trying to login the browser retuns a 504 Gateway Timeout.
    Further any SSL VPN Logins via SecuExtender fail as well. Only VPN via IPSec is still available.
    Other services are still operable. For example we could reach the internet, and accesses from outside via port forwarding are working as well.
  • Vagabound
    Even in the SecuReporter, nothing is recorded, very strange. 🤔
  • Vagabound
    Received the following message from the FW alert:
    No. Date/Time Source Destination Priority Category Note Message
    1 2025-01-24 08:49:31alert zysh zysh daemon ZySH daemon is busy.
  • Michael_I
    Michael_I Posts: 46 image  Freshman Member
    We have a similar issue since today. Our Atp200 didn´t work in the morning. I turned it off and after a reboot everything is working (Internet, VPN). But I can´t login to the atp "504 Gateway timeout". Whe hafe 2fa activated.
  • Michael_I
    Secureporter says:
    Device Disconnected
    Device "ATP200" is not connected. Please make sure device connection is stable so the log it uploads keeps SecuReporter running.
  • Omnia
    Omnia Posts: 60 image  Ally Member
    we similar problem, with 2 atp 200, we have 2fa actived with google auth… it's impossible to reach it after reboot all is down
  • Michael_I
    Correction: VPN is not working.
  • ilnaz
    ilnaz Posts: 8 image  Freshman Member
    Same problem with the device atp 200.
    There was an error when logging into the web interface: Wrong CLI command, device timeout or device logout.
    It doesn't allow access to the web interface right now. And the devices started to fall off. The Internet stops working
  • Vagabound
    When I log in to SecuReporter, I get this message:
    There seems to be a major problem with the services at Zyxel. 🙃
  • Mario
    Mario Posts: 111 image  Ally Member
    Zyxel Certified Network Engineer Level 1 - Security First Comment Friend Collector Seventh Anniversary
    same problem on atp 500 and 200
    over serial I see the following error:
    httpd is dead at Fri Jan 24 08:43:40 2025
    App watch dog try to recover httpd at the 3 time
    ALERT!!
    temporary working folder filesystem usage: 100%
    0 /tmp/sdwan_init
    0 /tmp/fetchurl
    0 /tmp/sdwan_interface
    0 /tmp/app_wd_event_trigger
    0 /tmp/dual_style
    0 /tmp/wtpConfUpdateRecord
    not able to login over serial!
