Device error, Wrong CLI command, device timeout or device logout.
same problem with FLEX 200
Zyxel is working to resolve, for the most recent update check here:
https://support.zyxel.eu/hc/en-us/articles/24159250192658-Firewall-Not-reachable-or-unresponsible-or-unable-to-boot-up0 -
Hello everyone, like @BCC said this is an official status for the problem:
At the moment there is NO remote solution, only on premise.
Hi everyone,
We are regret this issue happens and any inconvenance we caused.
This issue is due to the Application Patrol signature issue.
Please reference this FAQ to resolve this issue:
Zyxel Nebula Support
@Zyxel_CSO thank you for the update article.
Since the FTP is actually functional on affected devices (see the image), can't we just upload the new firmware onto the affected device? If yes, what folder should that be?
FTP firmware upload would be a lifesaver as we can't imagine doing this physically on devices located far away from us.
Martin Brys0 -
When Automatik daily firmware update is activated, will it get the new Firmware or is the console sulution still needed.
The issue can´t be fixed by FTP.
Automatic Daily firmware will NOT fix the issue if you are affected, then console firmware is required. If you are NOT affected, no action needed.0 -
If it can no longer be repaired automatically, my USG Flex 200 is now a piece of electronic scrap, great! 😠
To All users affected by the signature incident
I hope this message finds you well. I am writing to sincerely apologize for any inconvenience you may have experienced due to the recent issues related to the App patrol signature. We understand how disruptive this can be, and we deeply regret any negative impact it may have had on your experience.
We are actively working to resolve the situation, and we appreciate your patience as we address the issue. In the meantime, we have prepared a self-help SOP that should assist you in mitigating the problem. You can find the step-by-step guide at the following link:
https://community.zyxel.com/en/discussion/28056/recovery-steps-for-usg-flex-atp-series-application-patrol-signature-issue-jan-2025
We hope this guide will help you resolve the issue quickly and minimize any further disruptions. If you continue to encounter difficulties or need additional support, please do not hesitate to reach out to our support team at
cso_security@zyxel.com.twwith your region(country), model information (S/N) and contact info. We'd like to have contact with you to assist and resolve the issue caused by the signature incident.Thank you for your understanding and continued support.
Same Issue here, with 2x Flex100 and Flex200:
- no VPN working
- no access to web Interface : Gateway Timeout
- automatic restart
- no access via SSH:
/usr/sbin/gdb_parser_t.sh: line 33: /etc/zyxel/ftp/tmp/zyshd_bt/2025-01-24-09-09-38_zyshd.dbg: Permission denied
0x100f1310 argc:2 args:stop 0x104efb10 argc:2 args:regen-ap-config 0x10274938 argc:2 args:stop 0x100118c0 argc:1 args: 0x10021790 argc:2 args:stop 0x100114b0 argc:1 args: 0x1030ee00 argc:2 args:stop 0x10010e68 argc:1 args: 0x100114b0 argc:1 args: 0x10379f70 argc:3 args:upgrade successly 0x101815f8 argc:1 args: 0x103d0878 argc:3 args:eth1 from-kernel 0x1006c978 argc:4 args:show interface wan1 0x1007d0a0 argc:4 args:show interface _type 0x100116d8 argc:2 args:exit 0x100118c0 argc:1 args: 0x102490e0 argc:5 args:show rip interface wan1 0x100116d8 argc:2 args:exit 0x100118c0 argc:1 args: 0x10078a90 argc:3 args:eth2 up 0x10011840 argc:2 args:running-config 0x1030dd10 argc:1 args: 0x10010e68 argc:1 args: 0x100114b0 argc:1 args: 0x100116d8 argc:2 args:exit 0x100118c0 argc:1 args: 0x10010e68 argc:1 args: 0x100114b0 argc:1 args: 0x100116d8 argc:2 args:exit 0x100118c0 argc:1 args: 0x103d0878 argc:3 args:eth2 from-kernel 0x1002d420 argc:2 args:entriessh: line 1: /etc/zyxel/ftp/tmp/zyshd_bt/2025-01-24-09-09-38_zyshd.dbg: Permission denied
/usr/sbin/gdb_parser_t.sh: line 43: /etc/zyxel/ftp/tmp/zyshd_bt/2025-01-24-09-09-38_zyshd.dbg: Permission denied
Bad terminal type: "xterm". Will assume vt100.0
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
