FWA710 dropping 5G and returning to 4G.
Posts: 59  Ally Member
First Comment First Answer Friend Collector Third Anniversary
Hi all,
An annoying issue that has started in the last few days. I don't think it is a router issue, and I have also raised a ticket with EE about this. But thought I'd ask the question here also in case their is a known bug?
Using latest firmware for awhile now.
But this is what I'm seeing, randomly it returns to 4G (LTE-A):
I can either choose to reboot the router (hence the low uptime shown above) or, toggle the "access technology" to something that I don't get, like 5G-SA which forces a disconnect, then I change back to 5G-SA/5G-NSA/4G (Auto) to reconnect.
On reconnect, I get 5G:
My signal strength is pretty much OK.
RSSI -72 (Good)
RSRP -83 (Good)
RSRQ -11 (Good)
SINR 3 (Fair)
SINR could be better but I am 4KM away from the tower but I get decent ping and speeds.
So yeah, any ideas? As I'm stumped. 😁
Thanks.
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
  • Posts: 3,085  Zyxel Employee
    Hi @Noddy,
    This issue should be less related to the firmware. Additionally, you may feel free to share the ISP's feedback with us.
    Zyxel Melen
  • Posts: 59  Ally Member
    Thanks @Zyxel_Melen . When I logged a fault via the app with EE they said there were no issues. I've yet to call to take it further. Current workaround is to take the Cell and RFCN ID's and to add a 4G Lock. It drops randomly, but, reconnects with 5G again. So no more worrying about dropping back to 4G. But no fix, as of yet.
    I also plan to do a power down of all kit this weekend, to see if that helps.
Welcome!
Welcome!
