Plex for NAS326
where do I find the install script?
/i-data/<VOLUME>/.PKG/PlexMediaServer/gui/PlexMediaServer/pkgcgi.cgi
Again - thank you so much!
It all worked - although especially setting up Entware was painful…
Explained to others:
Follow the clear instructions here: https://github.com/Entware/Entware/wiki/Install-on-Zyxel-NAS542
Remember to run the setup scripts as root - being admin on the BusyBox is not enough…
then install tar and change every occurrence of 'tar' in the Plex install script into '/opt/bin/tar'
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
