NSA325: Trouble installing MetaRepository
Found solution on Constantins and also my problem (after hard restart the shares on windows are away):
https://zyxel.diskstation.eu/forum/viewtopic.php?f=4&t=24&start=20
"I've deleted both smbd- and nmbd-ZyXELSambaReplacement.conf.pid from /opt/var/run/, restarted the service and viola - it works again!"
A very BIG THX to Mijzelf for the great work
Also a BIG THX to loverman310 for solving that issue (SAMBA doesn't start after reboot)
I have got the same issue with new Samba in NSA320S.
After power failure SMB always stop working due to existing 2 old pid files in /opt/var/run/.
I bypassed this adding to CRON task which delete hourly both smdb and nmdb pid files
They are not needed and samba works fine without them and they are recreated after a reboot.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
