High Ping & Slow Wi-Fi on NWA50AX Access Points – Wireless Only
We are facing high ping latency, slow speed, and unstable wireless performance on our site "Office". We are using four Zyxel Nebula NWA50AX Access Points (2 per floor).
Issue:
- Wireless users experience:
- Ping spikes over 1000 ms (even to our own gateway)
- Packet loss
- Slow speeds
- Wired connections are stable.
Actions Taken:
- Initial setup:
- 2.4 GHz: Channel 2
- 5 GHz: Channel 48
- Later adjusted:
1) Changed 2.4 GHz on first floor to Channel 6
2) Changed Disassociate Station Threshold from -88 dBm to -70 dBm
- Smart Steering is enabled
Please help us with this issue.
Hi @Gopinath,
Welcome to Zyxel Community!
There are several factors that can affect WiFi performance. To optimize your WiFi, here are a few suggestions to help troubleshoot and improve it. Please refer to the following guides:
- [Nebula] How to deal with Wi-Fi disconnections or intermittent connectivity? — Zyxel Community
- How to Optimize Wi-Fi Connectivity with Nebula AP? — Zyxel Community
Additionally, here are a few tips you might find helpful:
- Ensure your AP's firmware is up to date.
- Verify that your PC's WiFi drivers are the latest version.
- Double-check that your AP is configured to use the optimal channels and bandwidth settings.
If you’ve already applied the correct settings but the issue still persists, please enable Zyxel Support Access and provide your Org. name to allow us directly investigate the problem on your site.
Zyxel Tina
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
