FWA510 drops connection after a few hours
2»
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @Scapin ,
    after a couple of hours, devices remain connected but loose Internet access (this is exactly what wifi devices display "connected/ no internet access"). I can no longer connect to the router with Zyxel Air either. However, the routeur's LED keep the blue/green colors.
    The FWA510's LED showing blue/green color indicates that it has established a cellular connection. However, it's unusual that wireless devices show "Connected/No Internet Access" despite this connection.
    Could you help to enable Zyxel support. Additionally, please provide us with the name of your Nebula organization/site here or via the private message by clinking to my account > Message. We will investigate the device further.
    If remote troubleshooting becomes necessary, we will contact you to arrange a session. Thank you for your cooperation.
    Zyxel_Judy
    Untitled Image
  • GS_FIN
    GS_FIN Posts: 4 image  Freshman Member
    i have the same problem with mine. It randomly loses internet connection (whilst the 5G signals remain strong and the device does appear connected).
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,134 image  Zyxel Employee
    Hi @GS_FIN
    Since you mentioned the signal strength is strong, we recommend enabling Network Monitoring on the device to observe whether this behavior stabilizes or improves over time. Path: Access device GUI and go to> Network Setting > Broadband > Cellular WAN Enable the "Network Monitoring" option
    Additionally, it will be helpful if you can record the "loses internet connection" timestamp. This allows us to compare the logs once you still have issue after enable network monitoring. Please also enable zyxel support access for us to check.
    Zyxel Melen
  • GS_FIN
    I checked the Security log and there is several DDoS attacks actually happening which I reckon is the root cause of the problem (and may be for many of us experiencing the issue). I have raised a ticket about this since I'm NOT able either to upgrade the firmware (any upload fails).
  • Zyxel_Melen
    Hi @GS_FIN
    Thanks for the information. Please help:
    1. Provide the ticket number with me.
    2. Enable Zyxel support access and provide your organization's name so I can help to check together.
    Zyxel Melen
Nebula Tips & Tricks
