FWA710 and third-party POE+ switch
Sometimes the link negotiation fails but I had I idea if your switch supports it change the link speed on the port for the Cerbo GX to 100Mb
Hi @ChrisLau
Thanks for the update. Let me update what I found. First, I tried to capture packet on FWA710 and the AP, but both of them didn't receive any DHCP packet. Both of them should received a DHCP request packet from this device. Also, the FWA710's Arp table doesn't list Cerbo GX.
Second, I noticed that the Cerbo GX sometimes shows it IP address on the AP's Current stations info, but sometimes it doesn't.
Not sure if the Cerbo GX was sleeping when I check, or the unmanaged switch has some issue.
Please help to try:
- Connect a PC to the unmanaged switch and open the Wireshark to monitor DHCP packet.
- Reboot the Cerbo GX to let it send the DHCP discovery packet.
- If you find the DHCP discovery packet from Cerbo GX, please also check if the FWA710 send DHCP request and the reset of DHCP flow (request/ACK packet).
Zyxel Melen1 -
At 02:35 today my installation went offline and i have no contact anymore. I guess this coincides with the time you updated the settings. No worries, this is not critical, but I’m unable to accesses it physically as this is a remote installation. I’ll be able to check this coming weekend.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
