Help setup network correctly.
bbfarm
bbfarm Posts: 3 image  Freshman Member
Hi All,
I recently got the Zyxel FWA710 for my farm network. This router serves as my 5G internet gateway for the farm. While setting it up, I realized that the built-in WiFi is only for management purposes — something I wasn’t aware of at the time of purchase. While I’m happy with the 5G reception, I want to explore the best way to set up a reliable WiFi network across the farm.
Here’s my current plan:
  • Connect Zyxel (LAN) → Gigabit Switch → (WAN) Access Point → WiFi
  • I want other devices to connect via LAN as well, which is why I’m using a switch.
My goals:
  1. Create a flat network where all devices are on the same IP range.
  2. Use the Zyxel as the DHCP server.
  3. Deploy multiple access points by running additional LAN cables from the switch to different areas of the farm.
Questions:
  • How do I configure the access points so there’s seamless WiFi coverage across the farm (single SSID roaming)?
  • What would be some recommended access points for stable outdoor and semi-outdoor farm use?
  • Is there anything else I should keep in mind to maintain a stable, farm-wide network?
Thank you
B
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,990 image  Guru Member
    Hi @bbfarm
    About the roaming, it is recommended:
    1. Ensure APs have overlapping coverage (15-20% overlap is recommended).
    2. Configure APs with the same SSID and security settings.
    You may refer to the following FAQs for more details:
    About the outdoor AP, you may consider NWA55AXE or WAX655E, which arms the ourdoor WiFi application.
    Just one reminder, since FWA710 doesn't support VLAN on LAN interface, you just need to ensure not to set VLAN on the SSID.
    Zyxel Melen
  • Zyxel_Melen
    Hi @bbfarm
    Zyxel Melen
  • bbfarm
    Where do I see the list of DHCP leases, I want to set static IP for my AP's and some other devices. Where do I see this?
  • Zyxel_Melen
    Hi @bbfarm
    You may check the connectivity in the home page, or the Network monitor > ARP table to check the DHCP clients.
    Connectivity:
    https://jam.dev/c/f1e3be5f-8a4d-4faf-9d65-139010b6b21c
    ARP table:
    Hope this helps.
    Zyxel Melen
  • bbfarm
    Hello Melen,
    Hope you are doing good. I have setup access point and I can see the lease on the Zyxel. And If i connect to a wifi of the access point internet works fine as well. However I want to make changes to some settings in the access point. I am unable to connect to the admin page of access point. How do i achieve this? Eg; the one highlighted in yellow below;
    As you see the ip addess is 192.168.2.185. If i try to put that ip in browser it says page unavailable.
    I tried both http and https. How do i access the admin page of my AP? Why are my devices not reachable with the ip address? I am on the same wifi as well of the AP.
  • Zyxel_Melen
    edited September 3
    Hi @bbfarm
    I'm not sure if this AP's default AP mode is NAT mode or bridge mode. If is NAT mode, it might not allow you to access it from uplink. I suggest checking with the AP's vendor about this issue.
    Zyxel Melen
