Zyxel Multy M1 frequently turning red and stops working
at home I have a system of 1 primary Multy and 4 Satellites. Usually every week I have to restart 2-3 of them because they turned red and stopped working. This is not how I expected the product to be. Can anyone help here?
Products probably out of warranty. Purchase date 2 years ago now.
Thank you!
Hi @TimRo21
It seems like you are over the maximum number of satellites (1 primary Multy with 2 Satellites). We recommend that you create two sites (1 primary Multy with 2 Satellites and another 1 primary Multy with 1 Satellite) to use.
Zyxel Melen0 -
I read somewhere that the Multy M1 can support for maximum 4 satellites.
Actually, I have one primary and three satellites and they work well.
Thank you very much for your answer. How would you implement this in a house with 3 floors?
The only Primary is sitting at the Router and spreads the connection to all the satellites.
Would it help to put a Ethernet Cable up to the highest floor to create another Primary one?
Do I have to create 2 different networks then so I can use 2 Primarys? So basically 2 AP's and then connect 2 and 1 satellites to them?
Thank you for your help!0 -
I know, thats why I asked how to implement your previous suggestion.
Thank you!
So I tried it with just 2 satellites connected and the problem still occurred. Anything else I can try?
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 343 Security Ideas
- 295 Service & License
- 471 News and Release
