FWA505 needs reboot every night
Baloudk
Baloudk Posts: 5 image  Freshman Member
edited November 2025 in Mobile Broadband
I recently purchased a Zyxel FWA505, and while it works well most of the time, it loses its internet connection every night. In the morning, the router is still powered on, but no devices have internet access until I manually restart the router.
This is quite problematic since my surveillance system and several smart home functions depend on a stable connection.
I have already:
  • Updated to the latest firmware (V1.19(ACKO.0)C0)
  • Tested with and without SIM PIN
  • Verified that the 4G/5G signal is stable in the area
What setting can I try, because this is driving me creazy
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,367 image  Zyxel Employee
    Hi @Baloudk
    Could you enable Zyxel support access so we can access to your FWA505 to check this issue? And since this will take some time to monitor, we suggest setting the schedule reboot to ensure your device have internet access in the morning.
    Enable Zyxel support access:
    Schedule reboot:
    Please navigate to Site-wide > Device > Mobile router to configure maintenance setting.
    Zyxel Melen
  • Baloudk
    Hi Melen
    Thanks for answer.
    I can't find the "Please navigate to Site-wide > Device > Mobile router to configure maintenance setting."
    I also noticed that if I use only 4G, the router doesn’t lose signal. However, when I run a speed test, the internet speed is around 50–60 Mbps.
    If I switch to NR5G Auto, the speed increases to about 200 Mbps, but then the connection sometimes drops during the night.
    So right now, the setting that works best is 4G — it provides a stable internet connection, although not as fast.
    Where do I find the - Invite Zyxel support as administrator - I Can't find the questions mark on the router to invite support.
  • Zyxel_Melen
    Hi @Baloudk
    Thanks for your update. May I know your ISP info? It could help us to investigate the 5G disconnect at night.
    This path is on Nebula control center, not the device local GUI.
    Please help to follow the below screenshot to find the help button.
    Zyxel Melen
  • Baloudk
    I am sorry, I can't find any place where the help button is. Please look at may attache file and tell me where to go to enable you to login in the router.
    We use ISP: Oister that is a part of 3
  • Zyxel_Melen
    Hi @Baloudk
    I noticed that your FWA505 didn't register to Nebula. The setting path on device's GUI is "Maintenance > Reboot > Schedule Reboot".
    However, to access your FWA505, we will need to use a function "Remote configurator" which is a Nebula live tool function (Free function). If you need our help to monitor the device and its logs, please help to register the FWA505 to Nebula and enable the Zyxel support access. Thanks.
    1. Create organization and register your FWA505.
    2. Enable Zyxel support access.
    Zyxel Melen
  • Baloudk
    Hi
    I have connected it to Nebula.But the "Help" button stills does not come on.
    Is is possible to call you, so you can guide me?
  • Zyxel_Melen
    Hi @Baloudk
    The help button is on the Nebula control center, not the FWA505's local GUI.😅
    You may check this video guide to turn on Zyxel support access.
    Zyxel Melen
  • mike79
    mike79 Posts: 5 image  Freshman Member
    I have the same issue with only stable connection on 4G on FWA501 did you get it fixed somehow
  • Zyxel_Melen
    Hi @mike79
    Could you describe more details about your issue? And which model is you using? We don't have a mobile router model call "FWA 501".
    If the mobile router can connect to 5G, but after specific time, it disconnected, you need to check:
    1. Is the 5G signal strength good? If the signal strength is poor, the mobile router will change to 4G to have stable connection.
    2. If it happens every night, you can try schedule reboot to ensure it connect to 5G every morning.
    Set on Nebula (Recommended):
    Untitled Image
    Set on device's GUI:
    Path is Maintenance > Reboot > Schedule Reboot.
    Zyxel Melen
