FWA505 needs reboot every night
I recently purchased a Zyxel FWA505, and while it works well most of the time, it loses its internet connection every night. In the morning, the router is still powered on, but no devices have internet access until I manually restart the router.
This is quite problematic since my surveillance system and several smart home functions depend on a stable connection.
I have already:
- Updated to the latest firmware (V1.19(ACKO.0)C0)
- Tested with and without SIM PIN
- Verified that the 4G/5G signal is stable in the area
What setting can I try, because this is driving me creazy
Hi @Baloudk
Could you enable Zyxel support access so we can access to your FWA505 to check this issue? And since this will take some time to monitor, we suggest setting the schedule reboot to ensure your device have internet access in the morning.
Enable Zyxel support access:
Schedule reboot:
Please navigate to Site-wide > Device > Mobile router to configure maintenance setting.
Zyxel Melen0 -
Hi Melen
Thanks for answer.
I can't find the "Please navigate to Site-wide > Device > Mobile router to configure maintenance setting."I also noticed that if I use only 4G, the router doesn’t lose signal. However, when I run a speed test, the internet speed is around 50–60 Mbps.
If I switch to NR5G Auto, the speed increases to about 200 Mbps, but then the connection sometimes drops during the night.
So right now, the setting that works best is 4G — it provides a stable internet connection, although not as fast.
Where do I find the - Invite Zyxel support as administrator - I Can't find the questions mark on the router to invite support.0 -
Hi @Baloudk
Thanks for your update. May I know your ISP info? It could help us to investigate the 5G disconnect at night.
This path is on Nebula control center, not the device local GUI.
Please help to follow the below screenshot to find the help button.
Zyxel Melen0
- 439 Beta Program
- 2.8K Nebula
- 201 Nebula Ideas
- 6.3K Security
- 503 USG FLEX H Series
- 325 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 458 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
