VMG3925-B10B drops 5GHz wireless several times a day - HELP!
Hi TJcph,
May I know it need to take how long for this “5G WLAN not be associated” happened ?
Is there a lot of traffic generated during this period ? How many clients connected to the router at that time ?
Hi AAAAL,This problem has been there right from the start when I swithched to fiber and the new Zyxel- hardware, whihc is 3 weeks now. I am on my second Zyxel VMG3925-B10B router.I don't know if it is a lot of traffic. I think my household is similar to others.Usually there are 3 mobile phones connected to the wifi, My son's computer, 2-3 iPads and then an occasional PS4 and Apple TV are also on the wifi when it fails. Can also be fewer and more. One iPhone, the PS4 and my son's computer are the only ones on the 5GHz. The rest are on 2.4.In the router menu is says that I should be able to connect 32 devices to each of the networks if I am not mistaken.Any suggestions?/TJcph0
Hi TJcph,
In order to provide you with a better assistance, we contacted you through private message to get more information, please check your message box.
I got fiber installed with the zyxel vmg3925-b10b router delivered as part of the installation. First few days both 2.4 and 5ghz worked fine. Now 5ghz is very unstable if at all available. If am close to router with device, have max 3-4 devices connected, 2.4 ghz channel works fine. Could it be a patch needed in the router software?
@Zyxel_Support_CPE please post any guidance here, not just in PM. It seems to be a general problem with the router?0 -
Hi Ptillegr,
Can you describe more detail “5ghz is very unstable“?
WLAN client can connect via 5G SSID, but sometimes traffic will be drop? Or 5G SSID disappear? Or other situation?
And please also share the firmwave version of your device.
Hi. I have the exact same problem as post #1, with the exact same router. Did you figure our What the problem was, or Can someone fra Zyxel please PM me?
Best regard
michael0 -
Hi Guldsteen,May I have the firmware version of your device? We will have generic fw to improve 5G wifi part, the schedule is 2019/3/E. Let me know your firmwave versoin first and then I will let you know if new version is suitable for your device or not.0
Dear Zyxel support,
i have the exact same issue and my router came with Firmware Version: V5.13(AAVF.11)C0_20180409B.
i have also downloaded V5.13(AAVF.12)C0 and tried to upgrade the FW, but it always rollback to the old FW version after 2-3 reboots.
Even during the short period the router running with the newer FW, AAVF.12, the 5G WiFi still disappeared after 3-4 hours regardless whether I logged on to 5G network or not. That’s also the reason I have to reboot the router to bring 5G WiFi back, which caused the FW rollback after 2-3 reboots. Really annoying!
meanwhile, 2.4G WiFi works just fine.
can you please also send a new FW to me?
thanks in advance!
Happy new year btw!
br, Xia0 -
Hi Toxiaxia,
The latest generic fw is V5.13(AAVF.12)C0, we expect to have next release on March/E.
You mention device will rollback to older version after 2-3 reboot. So did you try to reset your device after upgrading to V5.13(AAVF.12)C0? I am not sure if you ISP is control it keeps in older version or not, can you please ask your ISP for this?
Any news for a fix for this? I updated from the old V5.11(AAVF.3)C0 firmware to V5.13(AAVF.12)C0 and have the same issue with 5Ghz wifi either losing SSID or showing it but not connecting after a few hours.
I rolled back to the earliest firmware still available and have the same issue. Is it possible to allow access the the older V5.11(AAVF.3) firmware which was more stable?0
- 588 USG FLEX H Series
- 477 News and Release
