New mirror for nas-central.org
Because there is a version 1.3.0 available? Not for your hardware, but I think the update detector doesn't care.
Ok, that was a stupid question haha. I need to figure out how I can bypass this "update needed" thing so I can access my library with my devices.0
Any ideas?0
Hi, somehow cannot get up and running plex server. Did all the above. Plex seemed to be installed by cannot launch.
Starting Plex Media Server...failed?
/i-data/c01b0b12/.PKG/PlexMediaServer/share/PlexMediaServer/home/Plex Media Server: error while loading shared libraries: /i-data/c01b0b12/.PKG/PlexMediaServer/share/PlexMediaServer/home/libboost_system.so.1.59.0: internal error
What could be the issue?0 -
Replace my NSA320 with a NAS326 after lightning bricked the NSA320. Luckily I found this thread for the new location of the MetaRepository. Installed it successfully and added Entware first.
Only thing not working is the Pacages list on http://192.168.1.70:5000/pkg/Entware-ng/pkgcgi.cgi?chapter=Packages
It throws an "nginx/1.6.2"
Triedopkg update
to fix that, but after examining the page it seems the list comes from an iframe with source http://pkg.entware.net/binaries//Packages.html
Accessing this page directly, also gives me a 404.
Is this a known problem?
Regards, and glad to find my way back to the MetaRepository.
NAS326 + MetaRepository + Entware0 -
Is this a known problem?Yes. The webinterface is mainly a static page, containing a brief manual. The 'Packages.html' file is hardcoded, and meanwhile Entware-ng is changed to Entware, and the repo is changed. Entware itself doesn't care, as the changes are pushed to opkg.I just didn't bother to upgrade the whole package for this issue. 'opkg list' gives the same information.
Thank you very much for this: http://zyxel.diskstation.eu/Users/Mijzelf/FFP/packages/0.7/arm/
I own a DNS-320
I have a newbie question:
What's the difference between these 2 files:mc-4.8.1-arm-0.txzmc-4.8.1.7-arm-1.txz
Can I install any of them in my device or should I stick to arm-0 or arm-1 files?0 -
The number after the 'arm' is a revision. In this case the package is mc, it's own version is 4.8.1, it's compiled for arm, and the revision is 0 or 1. Both should work on your box, and I can't remember the difference. Some options which are compiled or not.
Hello Mijzelf, do you have any idea why the sources in the MetaRepository pkg config page cannot be updated?
I tried adding the /fw4/ directory to the MetaRepository sources, but after clicking Apply, it just reverts to the previous list of files. Might be a permission/ownership issue i suppose.
I'm using it on a Zyxel NSA320S with ffp 0.7, trying to install Enware-ng in order to upgrade Samba v2.
Thanks in advance!
If you have ffp, I guess you have shell access. The setting can be found in/usr/local/zy-pkgs/etc/MetaRepository.conf.1
- 221 Nebula Ideas
- 609 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
