New mirror for nas-central.org
I just found out about the merge from entware-ng to entware when searching for a way to use a newer samba version on the Zyxel NAS 542.
On https://github.com/Entware/Entware/wiki it states:
"See Upgrade from... from right column if you've got working Entware-ng/-3x installation."
but there are no "Upgrade from" pages.
So I just tried to install the new entware and try to merge the stuff myself.
Now I got some problems:
1) when I ssh into the NAS I get the error
"Could not chdir to home directory /home/shares: No such file or directory"
before, my homedir was "/i-data/fd19ae31/admin"
can I change that back?
I tried to create /home/shares/ but that got removed after restart.
2) my main reason to do all this was to install a new version of samba.
I did "opkg install samba4-server"
I restarted the NAS and "which smbd" shows/opt/sbin/smbd
but in top and ps I see the old "/usr/sbin/smbd" running instead./opt/sbin/smbd -VVersion 4.12.5/usr/sbin/smbd -VVersion 4.1.7
How would I get the new version to get started even after restart?0 -
About that homedir, are you logging in as admin? root has /home/shares, AFAIK. And are you using firmware or Entware ssh server? The first one uses /etc/passwd to find the homedir, and the other /opt/etc/passwd, which might be another file, but could also be a symlink to /etc/passwd.About smbd, I wrote an Entware-ng package to install Entware Samba on a firmware 4 device. I think it should also work on a firmware 5 device like yours. You can find it here:Basically it's only a start script in /opt/etc/init.d/ which patches /etc/init.d/samba.sh to start Entware smbd instead of the firmware one.0
yes I'm logging in as admin.
seems like I use the firmware ssh server now, changing that file doesn't survive the reboot though.
Well, might just install the entware ssh server later.
the link isn't working, it just reloads this thread. But I found the package at http://zyxel.diskstation.eu/Users/Mijzelf/Entware-ng/binaries/armv5/zyxel-samba-replacement_3.6.25_all.ipk
But I can't install it using opkg because it needs samba36-server
I tried to manually install it (move the S09ZyXELSambaReplacement file into /opt/etc/init.d/ and the conf file in /opt/etc/samba
but after that smbd didn't start at all on reboot.0 -
If you mean /etc/passwd, that's true. It's on a ramdisk. Does it show /home/shares/ as homedir for admin?
the link isn't workingThis forum software is completely borked. I just copied the link, and pasted it. Just like you, I suppose.
but after that smbd didn't start at all on reboot.Can you paste the output of
sh -x /opt/etc/init.d/S09ZyXELSambaReplacement start
and
sh -x /etc/init.d/samba.sh start
(In that sequence. The first script is supposed to change the second.)
Yes /etc/passwd shows /home/shares as homedir for admin.
I guess entware-ng changed that to /i-data/fd19ae31/admin but as I deactivated that it's back to default. I guess I will have to install an entware ssh later.
should the original smbd be running when running those commands?
I did both, first with original smbd running
The output of the first command: https://pastebin.com/Ws9LHDCH
I got asked if I want to remove some files, I said no each time.
Second command: https://pastebin.com/f67T018P
and without it running (with S09ZyXELSambaReplacement in init.d dir and rebooting)
First command: https://pastebin.com/0aLXbVNx
Second command: https://pastebin.com/5gFh26Ld
I read a lot of permission denied's. Can you repeat when logged in as root?
output of both commands: https://pastebin.com/LtGRZV4W
That looks good. It seems to me both smbd and nmbd are started, but maybe they error out? You can make it more verbose:/opt/sbin/smbd -d 1 -l /opt/var/samba.log -s /opt/etc/samba/ZyXELSambaReplacement.conf
entered the command as root, output here: https://pastebin.com/634CrMzC0
'-l /opt/var/samba.log' does something different than I thought. I thought it specified a logfile, but actually it specifies a directory.So you can create itmkdir /opt/var/samba.logand repeat/opt/sbin/smbd -d 1 -l /opt/var/samba.log -s /opt/etc/samba/ZyXELSambaReplacement.confLook also in the new logdir for clues.Your output shows some warnings about the config, it is possible that even if samba keeps running it will be unusable, because the (dynamically created) firmware config file is not compatible with samba4.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
