Problem with NAS326
Fabio64
Hi. Today I extracted my two hard disks from my NAS326 to read them via USB 3.0.
I was unable to read them from Windows (hard disks are formatted as GPT).
When I reinserted the discs, I could access the data the NAS began beeping continuously until I removed them.
I tried to update the firmware to the latest version available and now I can't access the files on the disks anymore.
How can I recover my data? Thank you 0
Not recommend to pull out the disk while NAS power up.It may caused some problem to the disk.As I know, it could not read the file via the USB.Could you share what is the status of the disk on the NAS now?0
I removed the disks with the NAS turned off. I inserted only one (the disks are in RAID 1) and I see the base folders of the NAS (admin, video, audio, photos) even with some data inside, but I no longer see the "work" folder that I had personally created and where were the other data. I found this guide: https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=013308&lang=EN but I'm afraid of losing files following it. What do you mean with "status of the disk on the NAS"? Thank you so much!
Have a look in the shares menu to see if you can re-enable the 'work' share.
If you're able to see the files in the disk, you can check the permission of the file.
- 441 Beta Program
- 210 Nebula Ideas
- 537 USG FLEX H Series
- 339 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
