Repository not visible in NSA325-v2 FW 4.81
Tomalamix said:Afterwards the NSA system populated the folder again but still no able to retrieve any list, buttons are all grayed out.The package system used to be very picky on the content of ZYPKG_INFO.tgz. On older firmwares (3.x) it even freaked out when you had a package installed which was no longer available according to ZYPKG_INFO.tgz. But in later revisions that was solved.You should be able to download the generated ZYPKG_INFO.tgz file fromhttp://<NAS-IP>:59999/NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz . For the syntax you can compare it to ftp://ftp2.zyxel.com/NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz .
That should be completely safe. The reset doesn't touch your data, it only erases some flash partition containing settings.Tomalamix said:How safe is for my backed up data to use the RESET button in the back of the unit?
Thank you for spending time on this
Ok, in System Setting - Firmware/Packages in the "Package" tab everything is grayed out, I can't do anything.
The "ZYPKG_INFO.tgz.log" have the following inside:"
HandleZYPKG_INFO /NSA325-v2/4.80/zypkgFindApp md5sum found /sbin/md5sumReadConfig RepositoriesStart of blockftp://ftp2.zyxel.com/+ ZyXEL/i-data/md0/admin/MyRepo/ LocalEnd of block8 start: 01:44:239 start: 01:44:237 start: 01:44:238: FetchZYPKG_INFO http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/ 87: FetchZYPKG_INFO /i-data/md0/admin/MyRepo/ 79: FetchZYPKG_INFO ftp://ftp2.zyxel.com/NSA325-v2/4.80/zypkg/ 98: FindApp curl found /usr/bin/curl7: FindApp curl found /usr/bin/curl9: FindApp curl found /usr/bin/curl7: Fetch /i-data/md0/admin/MyRepo/ZYPKG_INFO.tgz /i-data/md0/admin/zy-pkgs/MetaRepository/_i-data_md0_admin_MyRepo_.tmp failed7: Fetch /i-data/md0/admin/MyRepo/ZYPKGS /i-data/md0/admin/zy-pkgs/MetaRepository/_i-data_md0_admin_MyRepo_.tmp failed7: Failed7 stop: 01:44:248: Fetch http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/ZYPKG_INFO.tgz /i-data/md0/admin/zy-pkgs/MetaRepository/http___downloads.zyxel.nas-central.org_Users_Mijzelf_zypkg-repo_.tmp failed8: Fetch http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/ZYPKGS /i-data/md0/admin/zy-pkgs/MetaRepository/http___downloads.zyxel.nas-central.org_Users_Mijzelf_zypkg-repo_.tmp failed8: Failed8 stop: 01:44:259: Fetch ftp://ftp2.zyxel.com/NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz /i-data/md0/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NSA325-v2_4.80_zypkg_.tmp succeeded9 stop: 01:44:26Nothing changedTarHeaderFindApp curl found /usr/bin/curlFetch /i-data/md0/admin/zy-pkgs/MetaRepository/NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz - succeeded
The log file "zypkg.log" have the following inside:
"Request: /i-data/md0/admin/zy-pkgs/MetaRepository/NSA325-v2/4.80/zypkg/PHP-MySQL-phpMyAdmin_2.0_arm_009.zpkgTarHeaderFindApp curl found /usr/bin/curlFetch ftp://ftp2.zyxel.com/NSA325-v2/4.80/zypkg/PHP-MySQL-phpMyAdmin_2.0_arm_009.zpkg - succeeded
I see several failed operations in the ZYPKG_INFO.tgz.log log but i can't understand what to do.
Thanks0 -
Thanks0 -
Ok, i've emptied the \admin\zy-pkgs\MetaRepository\ folder and restarted the NASMijzelf said:Tomalamix said:Nothing changedMetaRepository has to sift the downloaded ZYPKG_INFO files, to glue them together to a meta file. This is quite expensive, and so the MD5 sums of the downloaded files are stored. As long as they don't change, no new meta file will be generated.I think your database is corrupted. You can reset it by removing the content of <NAS>\admin\zy-pkgs\MetaRepository\, and requesting a new update.Afterwards the NSA system populated the folder again but still no able to retrieve any list, buttons are all grayed out. But Then i tried to backup and rename "ZYPKGS" and "web_prefix", restarted the NAS and now it works, everything is populated in the MetaRepository folder and new "ZYPKGS" and "web_prefix" were created. Nice
nas-central.org is dead. The repository can now be found here:About this, how can i change that?Thanks again!
Ok, i've emptied the \admin\zy-pkgs\MetaRepository\ folder and restarted the NASMijzelf said:Tomalamix said:Nothing changedMetaRepository has to sift the downloaded ZYPKG_INFO files, to glue them together to a meta file. This is quite expensive, and so the MD5 sums of the downloaded files are stored. As long as they don't change, no new meta file will be generated.I think your database is corrupted. You can reset it by removing the content of <NAS>\admin\zy-pkgs\MetaRepository\, and requesting a new update.Afterwards the NSA system populated the folder again but still no able to retrieve any list, buttons are all grayed out. But Then i tried to backup and rename "ZYPKGS" and "web_prefix", restarted the NAS and it worked during the first restart, everything is populated in the MetaRepository folder and new "ZYPKGS" and "web_prefix" were created again. After I restarted the NAS all back to the same, all guttons grayed out and list empty.nas-central.org is dead. The repository can now be found here:About this, how can i change that?Thanks0
8: Fetch http://downloads.zyxel.nas-central.org/Users/Mijzelf/zypkg-repo/ZYPKG_INFO.tgznas-central.org is dead. The repository can now be found here:
How can i change that configuration?
In the webinterface of MetaRepository.Tomalamix said:How can i change that configuration?I see several failed operations in the ZYPKG_INFO.tgz.log log but i can't understand what to do.I think you misunderstood me. The firmware package manager is designed to fetch 1 package database from 1 server. MetaRepository is an 'in between' server, which fetches package databases from several servers, and combines them to a single package database. (ZYPKG_INFO.tgz), transparently. That server runs on your NAS, on port 59999. So you can download the combined package by entering http://<NAS-IP>:59999/NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz in your browser. (And if you had 2 ZyXEL NASses, you could let one use MetaRepository on the other, by using a web_prefix http://<NAS-IP>:59999 instead of http://localhost:59999).
Sorry to did not follow this for so long, I had some things to take care, but I'm back.
I've made a backup of all important stuff inside the NAS and done the RESET that takes everything down. Like you've said my data is all there.
About the repository all is in the same way, empty. Im becoming desperate here, this is really strange, even after a RESET things dont go normal. In my "desperate mode" I've emptied the folder "\\NSA325-V2\admin\zy-pkgs" and left only folders "MetaRepository" and "ffp", all other files deleted.
After this I went to the tab "Packages" in "System Setting - Firmware/Packages". I could retrieve a list but MetaRepository isn't there to be installed. I went to "\\NSA325-V2\admin\zy-pkgs" folder and now there is a ZYPKGS file dated from 2016/10/28.
Then I went to manually install the new repository, I've put the file "web_prefix" in "\\NSA325-V2\admin\zy-pkgs" folder and then i got this message:
"Package Name Version New Version MetaRepository 20160513zypkg013 20181001zypkg015 I pressed OK and nothing happens except now the list in tab "Packages" in "System Setting - Firmware/Packages" is empty again and all buttons are greyed out.
I've done more tests but none of those is working. This should be easier after a HARD RESET.
Thank you!0 -
I think you'd better uninstall MetaRepostory, and start over with a fresh web_prefix.
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
