Zyxel nas542 boot loop after installing OMV
the image is the one shared by you https://zyxel.diskstation.eu/Users/Mijzelf/NAS/542/and it has 6.99 MB, i rename it to uImage.520.bin from uImage.520ABAG1C0.bin0
That should be right. Maybe the load address is the problem. Try something else, like 82000000 or 2000000.
So, i made some progress using the bellow commands:
eth0.ipaddr=192.168.1.191
eth0.serverip=192.168.1.139
addpart /dev/mem 8M@0x8000(kernelraw)
addpart /dev/mem 8M@8M(kernel)
netload="/dev/mem.kernel"
tftp uImage.520.bin $netload
bootm ${netload}
It boots from the image but in the end, after restart i get bad magic number. Looking on this thread https://community.zyxel.com/en/discussion/7674/nas542-bootloop-after-debian-omv-get-a-new-firmware-solved/p4 i can see that some bootargs was modified on the config file, can you please help me with what i need to modify on the config file?1 -
So it boots the stock kernel, but after a restart nothing is changed? If you didn't do anything than booting the stock kernel, indeed nothing is changed. The idea is let the stock kernel use a Rescue stick (you can use the 540 one, when you exchange the ras.bin file by a 542 one, and set the right md5sum in the ras.bin.md5sum file) to flash the firmware, or a Universal usb_key_func stick to get telnet access to do some stuff.faierbol said:It boots from the image but in the end, after restart i get bad magic number.
- 441 Beta Program
- 293 Service & License
- 461 News and Release
