change channel on multy x
Chanter
Chanter Posts: 6 image  Freshman Member
edited February 2020 in Multy WiFi System
how do i change output channel on multy x?
#MultyX_Feb_2020
  • mustermark
    mustermark Posts: 1 image  Freshman Member
    I have the same problem with my Multy U. It prefers band 2 on 2.4 but there are two other networks at that band. I rebooted the device but nothing chenged so I factory resetted both multies but it was on band 2 again.
    2.4 is free after band 7 but it always prefers band 2 somehow, please add manuel channel selection.
  • Zyxel_Eric
    Zyxel_Eric Posts: 279 image  Zyxel Employee
    First Answer First Comment
    Dear Sir,
    We don't have plan to add the Channel selection on the Multy in the future.
    Thanks for your understanding.
    Best Regards,
    Eric
  • haruntan
    haruntan Posts: 3 image  Freshman Member
    I have the very same problem. İt didn't switch channels and use crowded channels.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,405 image  Zyxel Employee
    Hi @haruntan,
    Multy Plus support changing the 2.4G channel, the other Multy model do not support changing the channel.
  • vzstrict
    vzstrict Posts: 3 image  Freshman Member
    Friend Collector First Anniversary
    edited November 2021
    @Zyxel_Eric @Zyxel_Jerry how can we request new feature to be able to change the channel manually? It's impossible to use Multy X. It can't choose the right channel. I can't tell all my neighbors to reconfigure thier  routers everytime when Multy X choose "wrong" channel.
  • Zyxel_Jerry
    Hi @vzstrict
    Multy X supports auto-selection channel, it will scan of the available channels on the frequency range. The channel we selected is based on a wireless environment. If the device often choose a crowded channel, you can try to place the device in other placement.
    Or you can consider to buy a Multy Plus, Multy Plus support to change 2.4G channel manually.
