NAS542 500 Internal Server Error on USB External Drive
sheshman
I've NAS542, updated to latest version and did a factory reset after it(i bought as second hand that's why deleted everything with factory reset), so when i connect my 4TB western digital usb hard drive through front USB port, i can see my usb drive on external storage, opening file browser and clicking to my usb drive, then it waits for 5-6 seconds and returns 500 Internal Error.
Enabled SSH and connected to nas through ssh to see if there is a problem with file system, but "ls -l" returns nothing.
All other services works jut fine and i can use my usb hard drive on my windows & linux computers without any problem.
Any suggestions?
Any suggestions?
Best Answers
with your help,i've found the problem.Mijzelf said:So you have to run 'ls -l' in that directory, to see it there are any symlinks pointing out of the filesystem, or strange names, or ... .
As you can see on screenshot it was returning I/O error for one of the folders on USB Drive, so it wasn't an important one i deleted with rmdir command, now it works perfectly.
Thanks for your time and support.
If you have the possibility, do a filesystem check on that volume. Deleting that directory might not have removed all corruption.
Perhaps the USB power is not sufficient to supply certain size of external USB storage, or had you already plugged in the external power and still fail as well?0
good pointBlabababa said:Perhaps the USB power is not sufficient to supply certain size of external USB storage, or had you already plugged in the external power and still fail as well?
i don't think it's power issue because when i go \\mynasip i can see external usb drive and files in it 0 -
I find some post related.You can reference to these topic.0
Thanks Dexter,i already checked those subjects but no luck so farDexter said:I find some post related.You can reference to these topic.0 -
what is the output ofpwdls -lain the root of that mount?0
You are running 'ls -l' from the wrong place. The external disk is mounted in /e-data/<something>/ .0
oh sorry about that, i'm rookie on unix based systems.Mijzelf said:You are running 'ls -l' from the wrong place. The external disk is mounted in /e-data/<something>/ .
Here are the output of ls -la under /e-data
when i run ls it shows "90aa2d877a5254732fba90420060a799" i believe it's my usb hdd because when i "cd 90aa2d877a5254732fba90420060a799" and "ls" i can show my folders in usb drive
So you have to run 'ls -l' in that directory, to see it there are any symlinks pointing out of the filesystem, or strange names, or ... .0
- 213 Nebula Ideas
- 555 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
