Nebula Wifi Channel Settings not holding......
Hi there,
Could you tell me more detail about symptom likes which channels did you choose for radio 2.4GHz and 5GHz, which you configured at first, when you found that the WIFI channels ware changed, how it displayed, etc?
Please enable Zyxel Support Access by going to Help >> Support request, we would like to help you check the site and logs to clarify this issue.
Be a Community MVP: Win a VIP Deal Dash on Your Next Zyxel Purchase!
There is no symptoms. I'll manually set the channels and after some time I'll realize that I'm using different channels than I set. When I go in the settings, The channels are now set to (DCS).0
Hi there,
To configure the channel by manual, please go to Access point >> Configure >> Radio settings
Step 1: Scroll down to the end of page >> choose the AP >> Choose 2.4GHz/ 5GHz >> Click Edit
Step 2: Choose the channel, click Update
Step 3: Click Save
In the case you did follow the guide, however you still meet this issue, please enable Zyxel Support Access by going to Help >> Support request, we would like to help you check that.
Yes I do that. It just happened AGAIN. I just set them back to where I want them.
Support access is enabled.0 -
We accessed your site already. We will reply you once there is any update.
I just restarted my Network and when the APs came back up they did it again!
So it appears that they don't hold their settings during a system reset like a power loss.0 -
I have noticed a similar problem where NCC changes my 5GHz settings after a week or so - enables DCS as you are experiencing, and narrows the bandwidth from 160 to 80MHz. I set it back and a few weeks later I will find it changed again.1
Very annoying0
Hi Customers,
Thank you for your patience!
We have found the symptom that looks like you mentioned already. We’ll fix the issue as soon as possible.
We'll inform you if there is any update there.
Hi there,We are still checking your issue, however, it seems like the Zyxel Support function was closed after 21 days by default. Please help us enable again and choose "CSO account will be expired in:” as “Never” if you allow it.
By the way, if Nebula Wifi channel settings not holding again, please keep that setting and tell us, and then we could use the trouble shooting.
Thank in advance!
- 385 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 75 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 908 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 228 Switch FAQ
- 200 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
