NAS326 assign drive letter
bRiX
hi
earlier today i upgraded the firmware of my 326.
before i upgraded i had no issue finding it in NAS Starter Utility (i know its outdated, but easy mount), but now it cant find it whatso ever.. my other 3 nas326 has no issue at all.
i can access it through browser..
anyone who know why this happens? and possible a fix?
as said, it didnt have any issues before fw upgrade.
yours sincerely.
yours sincerely.
Best Answers
Hi @bRiX
Since the NAS Utility is End-of-Life, the NAS utility is not available on the new firmware https://community.zyxel.com/en/discussion/13907/nsa-starter-utility-eol-announcement#latest
I never used "Starter Utility" of any kind but the easiest way is to mount/connect drives is using "\\ip.to.your.nas\sharename" and use persisten mounting.0
JockeSve said:I never used "Starter Utility" of any kind but the easiest way is to mount/connect drives is using "\\ip.to.your.nas\sharename" and use persisten mounting.0
Hi @bRiX
bRiX said:JockeSve said:I never used "Starter Utility" of any kind but the easiest way is to mount/connect drives is using "\\ip.to.your.nas\sharename" and use persisten mounting.
On Windows (almost any version) just check the box for 'Reconnect at sign-in"
does this only work on latest FW? it looks like i cant get it to work with my other 3x NAS3260
AFAIK has the FW version nothing to do with how client (PC) does connect/mounts drives.
Maybe (a really wild guess warning here) it's the SMB version...0 -
oh noes
now im back to square one unfortunately..
we had a power outtage earlier on.. now i cant find it again
i can find it through zyxel findme and can connect/login..
however, not i cant find it in through file explorer
any ideas?
sorry for all my problems0 -
Did you connect to an IP address? In that case the IP address might be changed.
yes.. my ip changed from *.237 to *.236
i already tried connecting to the new ip, but it wont connect.. as said, then i can connect through find thingy.. and that shows *.2360 -
Your IP? You mean the IP of your PC, or do you mean the IP of the NAS? You should connect to the IP of the NAS.
- 435 Beta Program
- 175 Nebula Ideas
- 422 USG FLEX H Series
- 297 Security Ideas
- 272 Service & License
- 418 News and Release
- 89 Security Highlight
