NAS326 assign drive letter
bRiX
bRiX Posts: 18  Freshman Member
edited January 2023 in Personal Cloud Storage
hi
earlier today i upgraded the firmware of my 326.
before i upgraded i had no issue finding it in NAS Starter Utility (i know its outdated, but easy mount), but now it cant find it whatso ever.. my other 3 nas326 has no issue at all.
i can access it through browser..
anyone who know why this happens? and possible a fix?
as said, it didnt have any issues before fw upgrade.
yours sincerely.
Best Answers
«134
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,369  Zyxel Employee
    Hi @bRiX
    Since the NAS Utility is End-of-Life, the NAS utility is not available on the new firmware https://community.zyxel.com/en/discussion/13907/nsa-starter-utility-eol-announcement#latest
  • JockeSve
    JockeSve Posts: 82  Ally Member
    I never used "Starter Utility" of any kind but the easiest way is to mount/connect drives is using "\\ip.to.your.nas\sharename" and use persisten mounting.
  • bRiX
    finally.. got it to work.. thank you so much.. just one question.. how do i make it persistant?
  • JockeSve
    On Windows (almost any version) just check the box for 'Reconnect at sign-in"
  • bRiX
    does this only work on latest FW? it looks like i cant get it to work with my other 3x NAS326
  • JockeSve
    edited January 2023
    AFAIK has the FW version nothing to do with how client (PC) does connect/mounts drives.
    Maybe (a really wild guess warning here) it's the SMB version...
  • bRiX
    oh noes
    now im back to square one unfortunately..
    we had a power outtage earlier on.. now i cant find it again :(
    i can find it through zyxel findme and can connect/login..
    however, not i cant find it in through file explorer :(
    any ideas?
    sorry for all my problems
  • Mijzelf
    Mijzelf Posts: 2,931  Guru Member
    Did you connect to an IP address? In that case the IP address might be changed.
  • bRiX
    yes.. my ip changed from *.237 to *.236
    i already tried connecting to the new ip, but it wont connect.. as said, then i can connect through find thingy.. and that shows *.236
  • Mijzelf
    Your IP? You mean the IP of your PC, or do you mean the IP of the NAS? You should connect to the IP of the NAS.
