NAS326 assign drive letter
  • bRiX
    bRiX Posts: 18 image  Freshman Member
    yes.. its the ip for my nas
    this is what it shows when i log into the admin "panel"
    http://192.168.1.236/r51253,/desktop,/
  • Mijzelf
    Mijzelf Posts: 3,013 image  Guru Member
    Yeah, in that case the IP address is definitely 192.168.1.236. And what is the exact error message when you enter \\192.168.1.236\admin in the Explorer address bar?
  • bRiX
    Your file couldn’t be accessed
    It may have been moved, edited, or deleted.
    ERR_FILE_NOT_FOUND
    i get the same error if i try \\192.168.1.236\"share folder name"\
  • Mijzelf
    OK, that is not a wrong cached credential, I think. That looks like the samba server on the NAS isn't running at all. Have you already restarted the NAS?
    If yes, enable the ssh server on the NAS (control panel->Network->Terminal, or something like that) and login over ssh (in a command prompt type 'ssh admin@192.168.1.236') and execute
    'netstat -ltn'. There should be something listening on local address '0.0.0.0:139' and on '0.0.0.0:445'
  • bRiX
    yes
    something is listening at those 2 ports..
  • Mijzelf
    And can you actually connect? When I put http://<ip-of-my-nas>:445/ in my browser (Firefox) it waits forever (for reasonable values of ever), and when I then execute 'netstat -tn' I can see it is actually connected:
    $ netstat -tn
    Active Internet connections (w/o servers)
    Proto Recv-Q Send-Q Local Address           Foreign Address         State
    tcp        0      0 192.168.200.248:445      192.168.200.203:40156    ESTABLISHED
    Does smbstatus give any info?
  • bRiX
    yes.. it says established
  • Mijzelf
    In that case my poor mans analysis says the samba daemon is running, and ready for connections.
    Which suggests that the problem should be searched elsewhere. I wonder, you have 4 NAS326 in your network. Did you ever change their hostnames? Do they have the same credentials? I mean, when for some reason the client thinks it is talking to another box, and uses cached credentials, would that work?
  • bRiX
    i configged them all with static ip's last night. i can still login to admin panel on all 4 and the other 3 are running as smooth as always.
  • Mijzelf
    I don't know if that actually matters (fixed IP, I mean). It won't hurt, but the client is used to cope with changing DHCP addresses. So if it connects to a server, and the server says: 'Hello, I'm NAS326', it might think 'I know that guy, although he used to have another address, and I have a password cached somewhere'. In that case it's not helpful when 2 different boxes use the same hostname.
    You write that the other 3 are working. The release notes of the latest firmware say
    [Enhancement]
    * Remove NAS starter utility related information.
    [Bug fix]
    * [Vulnerability] Format string vulnerability
    * Remove nsuagent and do not support NAS starter utility.)
    * Users can't enable PHP-MySQL-phpMyAdmin and other 4 packages(Logitech®
    Media Server, WordPress, Gallery, ownCloud) on NAS GUI App Center.
    So, assuming the notes are complete, the only relevant change is the removal of the NSU agent. I never used it, but I can imagine the client side tool somehow interferes with the clients password cache, making it work, while you are now thrown back on the client default behaviour.
